Using AND and OR in a search term
Thread begun 7/16/2013 12:49 pm by iainmacdonald331081 | Last modified 7/17/2013 6:03 am by Jason Byrnes | 1520 views | 3 replies |
iainmacdonald331081
I've just added a simple search using just one search field, 'title', to a site. With single word search terms its working fine, but by default its not working with AND or OR - just returning blank results. I thought it was a case of changing the Type from Edit to Keyword in the server behaviour to use AND and OR.
I've attached the search and results pages, as well as a couple of screenshots from the server behaviour, showing As_it_is and What_I_tried.
I'm sure its something simple here, but whatever I try seems to either return no results, or return every record.
the search form uses GET as the method.
on the bindings panel, click the plus button and add 2 URL variables named:
Title
Search
Whemn you change the search type to Keyword, for the variable, click the lightning bolt icon and select the Title URL variable binding.
for the trigger, click the lightning bolt icon and select the Search url variable.
iainmacdonald331081
Thanks Jason - that worked great.
Is that always done by making those tweaks, or would I have missed something when setting up the search and results pages?
it all depends on the method of the search form.
if it is GET, you need to create the URL variables.
