How are Product Options normally written to the orderdetails table?
Thread begun 7/16/2013 8:31 am by Justin@AdventDesign | Last modified 7/16/2013 11:12 am by Justin@AdventDesign | 1210 views | 2 replies |
Justin@AdventDesign
I've been following the Product Options tutorial (http://www.webassist.com/community/tutorials/view_tutorial.php?tid=63&RID=5&SID=130520_optionstut) and have product options up and working on my detail and cart pages, and the info is setting properly in the eCart. I've also got the database admin pages set to select options available for the products and all seems to be working well.
My question: The tutorial seems to end at getting the info into the eCart and displaying it on the cart.php page. I understand how to display that info on the confirm.php page and write it to a database table, but what is the proper way to handle that data in the orderdetails table? My first inclination is to create an additional column in the orderdetails table for "size", and write the option info to that. But if at some point we have many options for different products, I'd be adding new columns for each and every one. I'm guessing there's another way I should approach it. Is there an additional tutorial for this end of the options process? If not, what is the standard way for handling that data in the orderdetails table?
normally, product options are written to the order details table each in it's own column.
for each option type, you would need to add a new column, and in the store order details table, bind the new option type column to the new column in the eCart object.
in reality, for each option type, you will need to edit the eCart object to add a new column, and edit the add to cart button to use the new option column.
It would be possible to expand on the options tutorial and make it more dynamic so that all options are stored in one options column of the cart, but this would require quite a bit of custom coding to accomplish.
we could help with configuring this in a premiere support appointment.
Justin@AdventDesign
Thanks Jason
I think we'll keep it simple for now and just add a column in the order details table.
