Sql Code and show utility
Thread begun 7/15/2013 2:17 pm by Jon Cunningham | Last modified 7/18/2013 9:23 am by Jason Byrnes | 6691 views | 26 replies |
Jon CunninghamBeta Tester
Hi Guys,
Could someone with Sql experience check my code please.
This is what I am trying to do.
I have a DetailProductID column in my database that has either a 1 or 2 written to it.
and I want an image / link to show if its a 1 and a different image / link if its 2.
This is what i have so far.
My Sql for DetailProductID with 1
SELECT users.UserID, orders.OrderUserID, orders.OrderID, orderdetails.DetailOrderID, orderdetails.DetailProductID
FROM users, orders, orderdetails
WHERE orders.OrderID = orderdetails.DetailOrderID AND orderdetails.DetailOrderID = orders.OrderID AND orderdetails.DetailProductID = 1 AND users.UserID = paramUserID
paramUserID Varibles with $_GET['UserID']
My php code
<?php if ($row_rsCourse1['DetailProductID'] == 1) { // Show if column... ?>
<span> <a href="users_ST_update.php?UserID=<?php echo($row_WADAusers["UserID"]); ?>"><img src="images/ST500DetailButton.png" alt="" width="200" height="38" /></a></span>
<?php } // Show if column... ?>
My Sql for DetailProductID with 2
WHERE orders.OrderID = orderdetails.DetailOrderID AND orderdetails.DetailOrderID = orders.OrderID AND orderdetails.DetailProductID = 2 AND users.UserID = paramUserID
My php code
<?php if ($row_rsCourse2['DetailProductID'] == 2) { // Show if column... ?>
At the moment all I am getting is the image and link for DetailProductID 1 for both
Am I over thinking this?
I have added my page code to the attachments.
Any help would be greatly appreciated.
Kind regards
Jonathon
the code inside of each if statement is the same.
this will give the same results for each if statement.
Hi Jason, Good Morning to you.
The link is the same for both show regions (Temp). But the code is different inside the if statement
and
the code in the attached page does not have my typo for the image file being the same.
For clarity, DetailProductID is set to 1 in the DB so in theory both should not show on the page Please see attached image
but you are using 2 diferant recordsets.
in the first recordset, you are retunring records where the DetailProductID is equal to 1, so the first if statement is true.
in the second recordset, you are returning records where the DetailProductID is equal to 2, so again, the if statement is true.
so if i had say 1 record set with a SQL statement of
WHERE orders.OrderID = orderdetails.DetailOrderID AND orderdetails.DetailOrderID = orders.OrderID AND users.UserID = paramUserID
then the following should work in theory.
<?php if ($row_rsCourse['DetailProductID'] == 1) { // Show if column... ?>
and
<?php if ($row_rsCourse['DetailProductID'] == 2) { // Show if column... ?>
<span> <a href="users_ST_update.php?UserID=<?php echo($row_WADAusers["UserID"]); ?>"><img src="images/DetailButton.png" alt="" width="200" height="38" /></a></span>
So if customer purchases course 1 all that will show is button for course 1 and if they purchase course 2 the just button 2 will show.
Therefore if they purchase both courses both buttons will show?
Regards
Jonathon
you would need a repeat region to loop through the recordset to show all courses purchased.
Ok I am with you so far but each course has its own DetailProductID and should only show the link when a course has been purchased. Each link has its own landing page which are different for each course
Hence I was going for a show if statement as I can then list all courses and ones that are purchased under orderdetails.DetailProductID will show with there own unique link.
thats all well and good, but you still the repeat region to loop through the recordset.
Ok So using the above code can you tell me how I go about using the repeat region to loop through the record set.
Many thanks for the advice.
Kind regards
Jonathon
simply add a repeat region around the code.
