PHP pages not connected to MySQl database on hosted site
Thread begun 8/15/2009 1:45 pm by cmartimo386205 | Last modified 6/10/2011 6:44 am by Jason Byrnes | 6933 views | 13 replies |
cmartimo386205
I have created a website with Dreamweaver and successfully have connected my *.php pages to the MySQL database. When I upload my site to my webhost (1and1), my php pages no longer can find the MySQL database because they are looking for it on the testing server.
I get the following error:
Fatal error: main() [function.require]: Failed opening required 'Connections/db1996.php' (include_path='.:/usr/lib/php') in /homepages/44/d289565916/htdocs/drygoods/PATTERNS.php on line 5
which you can see in person at patterns.php
What information should I be adding on line 5?
thanks
cindy
I-CRE8Beta Tester
The error that you have provided suggests that you have not uploaded Connections/db1996.php. So to start with make sure that your remote site contains this file and then ensure that the connection information contained match what your host gives you.
cmartimo386205
Still not working
The File Connections is there and in it is the db1996.php file. The php file contains the correct database name, host name, password, etc. I am disappointed that the eCart and DataAssist products contain no information about how to put your site online. Only how to run it on your computer.
I-CRE8Beta Tester
That page cannot find the connection file, that's what the message means, looking at the message again I suspect that the connection file is in location /htdocs/Connections/db1996.php which means that the link to your connection file should look like this:
<?php require_once('../Connections/db1996.php' ?> and not <?php require_once('Connections/db1996.php' ?> note the extra "../"
cmartimo386205
same error
Thank you for the suggestion but now my error is slightly different:
Fatal error: main() [function.require]: Failed opening required '../Connections/db1996.php' (include_path='.:/usr/lib/php') in /homepages/44/d289565916/htdocs/drygoods/PATTERNS.php on line 5
PATTERNS.php
Any other thoughts?
thanks
cindy
I-CRE8Beta Tester
Cindy,
there is a problem with the paths to your files or your connection folder is in the wrong place can you give the full path to your connection folder ?
cmartimo386205
full path
The path to my connection on my home computer looks like this:
C:\inetpub\wwwroot\drygoods\connections\connDGD.php
when I upload the drygoods folder to 1and1 the webspace explorer looks like this:
I am very new at this, but everything is working on my computer. I am assuming that because the MySQL database is in a different location that it was that the connDGD.php file cannot find it - therefore the error. I do not know what to include in either file to point one towards the other. 1and1's FAQ do not include any info about it, so I assume it is just something I should know, but don't.
thank you
cindy
I-CRE8Beta Tester
Originally Said By: cmartimo386205
In the orinal error message you provided it was "Connections" with an Upper Case C and not "connections" all lower case maybe this is the cause of your frustration ?
Also given where your file is you would need to change the include to look like this I suspect
<?php require_once('connections/db1996.php' ?>
cmartimo386205
new problem
Okay, so changing the folder to a capitol "C-(Connections)" fixed that. And I put in the 1and1 required hostname, username and password and now I have this error:
No database selected
patterns.php
cindy
I-CRE8Beta Tester
If that is the case either you have not uploaded your database from your machine to 1and1 or there is a problem with the connection information you have entered.
