search - replace spaces in search with commas
Thread begun 7/15/2013 11:16 am by mrs | Last modified 7/16/2013 8:48 am by Jason Byrnes | 2494 views | 5 replies |
mrs
I need to reduce search results returned, and I am going to have more than one repeated list of search results due to three different recordsets for three different tables in my DB.
I need to replace spaces with commas, but my code isn't working for some reason. By that I mean if I type 'test', I get 93 results. If I type 'test sweden', I still get 93 results... what ever I type, I get 93 results!
This is my replace code:
// line added to insert commas before spaces which are inputted by the user during searches
if(isset($_GET["searchbox"])) $_GET["searchbox"] = str_replace(" ", ", ", $_GET["searchbox"]);
This is one of the WA search codes:
//WA Database Search (Copyright 2005, WebAssist.com)
//Recordset: rs_eventslist;
//Searchpage: search-results.php;
//Form: searchform;
$WADbSearch1_DefaultWhere = "";
if ((isset($_POST["WADbSearch1"])) && ($_POST["WADbSearch1"] != "")) {
$WADbSearch1 = new FilterDef;
$WADbSearch1->initializeQueryBuilder("MYSQL","1");
//keyword array declarations
$KeyArr0 = array("fld_eventNAME", "fld_eventLOCATION", "fld_eventINTRO", "fld_eventDETAIL", "fld_eventVENUE", "fld_eventMAPTITLE", "fld_eventMAPADDRESS", "fld_eventMAPDESCRIPTION", "fld_eventEMAIL", "fld_eventURL");
//comparison list additions
$WADbSearch1->keywordComparison($KeyArr0,"".((isset($_POST["searchbox"]))?$_POST["searchbox"]:"") ."","AND","Includes",",%20","%20","%22","%22",0);
//save the query in a session variable
if (1 == 1) {
$_SESSION["WADbSearch1_searchresults"]=$WADbSearch1->whereClause;
else {
//get the filter definition from a session variable
if (1 == 1) {
if (isset($_SESSION["WADbSearch1_searchresults"]) && $_SESSION["WADbSearch1_searchresults"] != "") {
$WADbSearch1->whereClause = $_SESSION["WADbSearch1_searchresults"];
else {
$WADbSearch1->whereClause = $WADbSearch1_DefaultWhere;
else {
$WADbSearch1->whereClause = str_replace("\\''", "''", $WADbSearch1->whereClause);
$WADbSearch1whereClause = '';
This is my search form code:
<form action="search-results.php" id="searchform" name="searchform" method="get">
<input name="searchbox" type="text" id="searchbox" placeholder="Search...">
<input type="image" src="../images/search-trans.png" width="26px" height="26px" border="0" alt="GO" name="button" id="button" value="Button">
</form>
Am I not meant to be using the 'searchbox' to replace the spaces with commas?
Thanks.
your form is using the get method, but the trigger for the search is looking for a post:
change that to:
if ((isset($_GET["WADbSearch1"])) && ($_GET["WADbSearch1"] != "")) {
mrs
Aha... I missed that bit, however, I did initially have it all set to post. Would get or post make a significant difference?
Also, something that has just popped into my head is that I am using an image as the submit button rather than an actual button. Do I need to address the code in the same way as I would do for inserting to the database. I recall I had to change the trigger code from 'submit' to something like 'x_submit' because it was an image.
I'm still getting the same results... 93 regardless!
I've added the page just in case you need to see it in it's entirety!
mrs
This post has been deleted.
mrs
I did have another post which was saying how the search was being ignore because I was trying to insert into a locked region of a template. As it had already worked and I had been getting some results, I didn't believe this to be true. However after releasing the page from the template, I now see that a hidden field has been added. This is the form now:
<form action="search-results.php" id="searchform" name="searchform" method="post">
<input type="image" src="images/search-trans.png" width="26px" height="26px" border="0" alt="GO" name="button" id="button" value="Button">
<input type="hidden" name="WADbSearch1" value="Submit">
</form>
<input type="hidden" name="WADbSearch1" value="Submit"> was added. What is this used for, and is it needed for what I am trying to achieve? Also, just to ask again, should I be using GET or POST for the switching of spaces to commas?
the WADbSearch1 form element is being used for the trigger.
as for whether to use get or post, it really doesn't matter to much as long as it is consistent.
your current form is set to use POST, so the code for replacing the commas should use the POST collection, your previous form was set to use GET, that is why i suggested converting to the GET collection.
look at the form tag to determine which should be used.
