adding second add to cart button
Thread began 7/15/2013 5:10 am by Christie | Last modified 7/30/2013 11:00 am by Christie | 318 views | 2 replies |
Christie
Hi - In my test pages, I have successfully gotten one "add to cart button" to work with the shopping cart (ecart5). I have 4 products and each product has multiple options so will need to add an "add to cart button" on each of the other three detail pages - each product shares only some of the options. I do have the columns already set up. I am not sure what the process is for adding a second (and third and fourth) "add to cart button" on a new page. Any help would be appreciated.
IT is the same processs for adding the second add to cart button as it was for adding the first.
Place the curisor on the page where the add to cart button should go.
go to Insert -> WebAssist -> eCart -> Add to Cart button.
sounds like you are using Static products, so select the Add Static option. set the Go To page to the cart page.
on the bindings panel, add the information to the cart columns for the product.
Christie
Yes, I am using a static cart. Just wanted to let you know that your directions worked perfectly. Thank you.
