redirect base on user level
Thread begun 7/14/2013 3:20 am by Col Foster | Last modified 7/17/2013 3:27 am by Col Foster | 4123 views | 8 replies |
Col Foster
I need to redirect users with user level "1" to my admin section & user level "2" to the members section.
I've tried this code from another post in my login success page (modified version in attachment) without success.
Is this solution still current?
if(!session_id()) session_start();
switch($_SESSION['UserLevel']) {
case "admin":
header("Location: admin_index.php");
break;
case "visitor":
header("Location: visitor_index.php");
break;
CraigRBeta Tester
what values are you storing in your 'UserLevel' session variable ?
You say you want to redirect user level '1' and '2' - but your switch statement is using 'admin' and 'visitor'
Do you need to change your case options to read case '1' and case '2' ??
Col Foster
Thanks, I had changed to 1 & 3 (2 was a typo) The posted code was an example from an earlier thread.
My code in attachment
Col Foster
Thanks again, I've got that one sorted. I had uLevel instead of ulevel.
I have another question.
I would like some pages to be accessed by user levels "1" & "3" can this be done?
CraigRBeta Tester
Yes, you can do this.
Here’s one way I did it.
Create a number of access rules, through the access rules manager, and apply the appropriate access rule to the relevant pages.
For example, imagine you have 3 user groups, let’s call them 3, 2, 1
create the conditions which allow the rule to be met, so rule ‘Group 1’ could be
‘Allow if <?php echo $_SESSION['userLevel']; ?> = 1
then create as many access rules as you need
In the access pages manager, you apply the rule to allow access if the condition is met or redirect (eg to login page) if it isn’t.
you can also do this with hierarchical user levels, so if you have a hierarchy, such as
member, admin, group admin, each corresponding to a different user level eg 3, 2, 1
you set up an access rule so that ‘group admin’ user level is 1
you set up an access rule so that ‘admin’ user level is 2 OR 1, so all group admins are also admins
you set up an access rule so that ‘member’ user level is 3 OR 2 OR 1, so all admins and group admins are also members.
Col Foster
Thanks Craig, I'll give that a go
I may be back :o)
Col Foster
Sorry,
I was ok up until,
I'll need a bit of a walk through for this if that's ok.
Is there no way the "restrict access" code applied to a page could be duplicated to allow access to different user levels
CraigRBeta Tester
i'm sure you could do it that way, but it would probably mean hand coding all of the pages, as I don't know if the Security Assist- Manage Site Access wizard or the security assist server behaviors could cope with that.
Here's the logic (for what its worth) of what I did.
Imagine Members have a userLevel of 1, Administrators 2, Group Administrators 3
I wanted members to see some pages not generally accessible to the public
I wanted administrators to see some pages not accessible to the public or members, but I also wanted then to be able to see members pages
I wanted group administrators to see some pages not accessible to the public or members or administrators, but I also wanted then to be able to see members and administrators pages, - so effectively I have a cascading hierarchy where group admins can access pretty much everything, admins most things, members some things and the public, everything else. Get it ?
What I then did was create access rules, so that the
Members rule condition was to allow access if the userLevel session variable was 1 or 2 or 3
Administrators rule condition was to allow access if the userLevel session variable was 2 or 3
Group Administrators rule condition was to allow access if the userLevel session variable was 3
So if an admin logs in, they are userLevel 2, so can access all pages accessible to members and administrators (and public), but not group administrators.
Then you apply page access security either via the wizard or the server behaviors.
Col Foster
OK, it took a while but the penny has dropped. All working now.
Many thanks!!
