SALT & CRYPT
Thread begun 7/11/2013 2:45 am by Col Foster | Last modified 7/12/2013 1:48 pm by Col Foster | 5331 views | 10 replies |
Col Foster
SALT & CRYPT
I've created security assist pages & encrypted the pwd & email address using CRYPT.
I've also added a salt string to the wa_securitykey.php file but can only see the 13 character CRYPT string in my database.
Is there another step I need to take to add SALT?
crypt is capable of generating an encrypted string using multiple encryption methods as long as they are supported bu the server.
the encryption method used depends on the format of the salt string.
see this page for details:
http://php.net/manual/en/function.crypt.php
Col Foster
Understood Jason,
but I thought that by modifying wa_securitykey.php, my SALT string would be added to the end of the 13 character string in the database generated by CRYPT.
the salt string gets added to the beginning of the the string that gets stored in the database, but the salt string must conform to one of the recognized formats.
again, see the crypt manual page for more information:
Col Foster
Thanks Jason PM sent
Originally Said By: Col Foster
Col Foster
"Probably the most secure would using crypt with a salt string for the SHA512 algorithm."
Would choosing "Crypt" from the options acheive this?
Yes.
have you read the crypt manual page that i have linked to?
crypt is capable of using different algorithms. one of the algorithms it can use is SHA512 if the SHA512 library is installed on the server.
the algorithm that will be used by the crypt library depends on the format of the salt string.
if you visit the crypt manual page that i linked to, it gives the example salt string of:
$6$rounds=5000$usesomesillystringforsalt$
in the example is encrypts the sting:
rasmuslerdorf
using the above salt as:
$6$rounds=5000$usesomesillystri$D4IrlXatmP7rx3P3InaxBeoomnAihCKRVQP22JZ6EY47Wc6BkroIuUUBOov1i.S5KPgErtP/EN5mcO.ChWQW21
Col Foster
I've tried using the example $6$rounds=5000$usesomesillystringforsalt$ verbatim and it returns an undefined variable error.
I also tried it without the 4 "$". I was able to register but the string in the database was still the standard (for crypt) 13 characters.
escape the $ character with a forward slash:
