Could Data Assist be deleting my connection files?
Thread begun 7/10/2013 3:19 am by Daryl | Last modified 7/11/2013 6:58 am by Ben Pleysier | 2900 views | 3 replies |
DarylBeta Tester
I am using Dreamweaver CC and am having problems connection to my database.
As I have mentioned earlier, my site is set up correctly, I have a testing server and I have ensured that the _mmServerScripts folder is in the correct location and has the correct files in it - MMHTTPDB.php mysql.php WA_DBScript.php These files I have got from: C:\Users\Username\AppData\Roaming\Adobe\Dreamweaver CC\LocalLanguage\Configuration\Connections\Scripts\PHP_MySQL\_mmDBScripts
I can create recordsets and connect to the database through DW CC however as soon as I connect DataAssist the MMHTTPDB.php and mysql.php files get deleted and as such Data Assist can not see the columns in my tables and then I can not make any more connections directly from DW CC until I upload the files again.
Please help!!
DarylBeta Tester
Here is the server error log for that folder in case it helps:
[10-Jul-2013 01:16:11] PHP Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /home/k9sar/public_html/_mmServerScripts/WA_DBScript.php on line 80
[10-Jul-2013 01:16:11] PHP Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /home/k9sar/public_html/_mmServerScripts/WA_DBScript.php on line 132
[10-Jul-2013 01:16:18] PHP Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /home/k9sar/public_html/_mmServerScripts/WA_DBScript.php on line 80
[10-Jul-2013 01:16:18] PHP Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /home/k9sar/public_html/_mmServerScripts/WA_DBScript.php on line 132
[10-Jul-2013 02:07:27] PHP Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /home/k9sar/public_html/_mmServerScripts/WA_DBScript.php on line 80
[10-Jul-2013 02:07:27] PHP Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /home/k9sar/public_html/_mmServerScripts/WA_DBScript.php on line 132
[10-Jul-2013 02:07:34] PHP Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /home/k9sar/public_html/_mmServerScripts/WA_DBScript.php on line 80
[10-Jul-2013 02:07:34] PHP Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /home/k9sar/public_html/_mmServerScripts/WA_DBScript.php on line 132
[10-Jul-2013 05:13:50] PHP Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /home/k9sar/public_html/_mmServerScripts/WA_DBScript.php on line 80
[10-Jul-2013 05:13:50] PHP Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /home/k9sar/public_html/_mmServerScripts/WA_DBScript.php on line 132
[10-Jul-2013 05:13:57] PHP Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /home/k9sar/public_html/_mmServerScripts/WA_DBScript.php on line 80
[10-Jul-2013 05:13:57] PHP Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /home/k9sar/public_html/_mmServerScripts/WA_DBScript.php on line 132
[10-Jul-2013 05:16:41] PHP Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /home/k9sar/public_html/_mmServerScripts/WA_DBScript.php on line 80
[10-Jul-2013 05:16:41] PHP Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /home/k9sar/public_html/_mmServerScripts/WA_DBScript.php on line 132
[10-Jul-2013 05:16:48] PHP Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /home/k9sar/public_html/_mmServerScripts/WA_DBScript.php on line 80
[10-Jul-2013 05:16:48] PHP Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /home/k9sar/public_html/_mmServerScripts/WA_DBScript.php on line 132
here is an updated copy of 2 files that should go in the users configuration to correct the problem.
for help finding the configuration folder, see the following tutorial:
http://www.webassist.com/community/tutorials/view_tutorial.php?tid=95
from there, the attached files should be copied to:
/shared/webassist/libary/WA_Databases.js
shared/webassist/PowerCMS/PowerCMS_Shared.js
Ben Pleysier
Thank you Jason,
I wish I had seen this two days ago. As it stands now I'll enter the real world as the bald one.
