Parse error: syntax error, unexpected T_VARIABLE
Thread began 7/08/2013 7:22 am by Heckie | Last modified 7/08/2013 8:34 am by Heckie | 3411 views | 6 replies |
Heckie
I am getting the following error on some product pages:
Parse error: syntax error, unexpected T_VARIABLE in /home/eagle/public_html/concierge/groceries/beer-cider.php on line 1
They work fine on local testing server, but not on remote server.
I cannot see any syntax error on the first line (attached), as it is just the standard WA require once lines.
I am using Dreamweaver CC on Mac.
I dont see anything obvious.
Heckie
Randomly if I 'save as' to a different folder (one level up) updating links, then 'save as' again (updating links again), overwriting the original, it seems to work fine! Maybe a DW bug?
I have noticed strange behaviour using the Server Behaviours panel i.e. when you select a behaviour, it select random lines in the HTML, and if you make changes it can insert the code into random lines.
Has anyone else noticed this?
I have provided the details below.
What are you using to upload the files to the Server?
when i download a file from the FTP Server, the code has been compressed to one line and corrupted. for example:
<?php//WA eCart Includerequire_once("../WA_eCart/cartEagleBrae_PHP.php");?><?php require_once('../../Connections/connEagleBrae.php'); ?><?php$cartEagleBrae->GetContent();?><?phpif (!function_exists("GetSQLValueString")) {function GetSQLValueString($theValue, $theType, $theDefinedValue = "", $theNotDefinedValue = "") {  if (PHP_VERSION < 6) {    $theValue = get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;  }  $theValue = function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);  switch ($theType) {    case "text":      $theValue = ($theValue != "") ? "'" . $theValue . "'" : "NULL";      break;        case "long":    case "int":      $theValue = ($theValue != "") ? intval($theValue) : "NULL";      break;    case "double":      $theValue = ($theValue != "") ? doubleval($theValue) : "NULL";      break;    case "date":      $theValue = ($theValue != "") ? "'" . $theValue . "'" : "NULL";      break;    case "defined":      $theValue = ($theValue != "") ? $theDefinedValue : $theNotDefinedValue;      break;  }  return $theValue;}}mysql_select_db($database_connEagleBrae, $connEagleBrae);$query_rsProducts = "SELECT * FROM Products WHERE ProductCat = 2";$rsProducts = mysql_query($query_rsProducts, $connEagleBrae) or die(mysql_error());$row_rsProducts = mysql_fetch_assoc($rsProducts);$totalRows_rsProducts = mysql_num_rows($rsProducts);?
Try using a 3rd party ftp program like File Zilla.
Heckie
I was using Dreamweaver CC, but Ive re-uploaded with 3rd party software and seems to work.
Thanks.
Perhaps a Setting in Dreamweaver is causing the issue. Under DW Settings, go to Code Format and set the Line Break type to LF (Unix).
If you continue to have problems, i would contact Adobe support.
Heckie
Thanks. I deleted the folder from the server, and re-uploaded with DW CC to test, and it seem to work fine now.
