PS4 layout wrapped after uploading PS3 (or older) product table
Thread begun 7/08/2013 6:44 am by Jared Lui | Last modified 7/08/2013 7:36 am by Jason Byrnes | 1489 views | 2 replies |
Jared Lui
I manually uploaded the product table from an old PS install of 5+ years ago after adding the missing columns and matching the settings, etc.
Everything is fine except that the layout is messed up. For instance the index page using the default layout has the Featured, About, Most Popular columns wrapping under each other rather than floating across.
I'm guessing that this is due to the size of the thumbnail images being larger in the older PS? So to fix I would need to tweak the CSS?
I wont have a chance to mess with it until later today. Just wanted to see if I'm barking up the right tree. And if someone knows the correct file off the top of their head. If not, later when I figure it out I'll post the result.
Thanks!
Jared Lui
UPDATE
I just got home and did some testing. I am not sure what the problem was as swapping between the default test images and the images I had in place didn't make a difference and looking at the CSS there should not have been an issue. Anyway, when I removed the old product table and replaced it with the default one it seemed fine. When I replaced it again it was messed up.
What I ended up doing was changing the featured product tot another item and it fixed it. Even reverting back to the old featured item seems to be okay now. I'm guessing that the data needed to be refreshed??
This may never happen to anyone else but if so, there you go...
The PS3 products table does not have the same structure as the PS4 products table.
you will need to run the install/scripts/runsynch.php file to update the products table so it includes all columns
if you need further assistance, please post a link where i can see the problem.
