Dynamic attribute lines showing server behaviors
Thread begun 7/03/2013 2:40 pm by barkmail | Last modified 7/11/2013 1:10 pm by Jason Byrnes | 2933 views | 5 replies |
barkmail
Will attach file for your review. Pretty much all my webpages now list along with the add a cart within server behavior, the line dynamic attributes. A few webpages only list dynamic attribute and the cart button is totally corrupted. How do I repair?
on the tagscrystal2.php page, it shows the dynamic attribute behavior because of the text area. eCart does not recognize the textarea , so shows the dynamic attribute.
to troubleshot the pages that do not show the add to cart buttons, behavior, i will need you to send a copy of one of those pages so i can look at the code.
barkmail
Here is a file that shows only dynamic attribute listings under server behaviors. ALL my files are showing dynamic attributes within server behaviors. That's why I also sent you the ecart file....
This isn't the first time this has happened to me. Please refer to my forum posts from 2/2013 "ecart changed". I tried those suggestions, but it didn't repair this time....
Like i said before, the dynamic attribute line shows because of the text area, it is not really a probelm and can be ignored.
the add to cart button behavior does not show because the addf to cart code has the following line duplicated:
$ATC_RedirectAfter = "../../cart.php";
it should be:
$ATC_RedirectIfIn = "../../cart.php";
barkmail
Hi Jason
I don't know where to go to make that edit. Can you provide some more detail as to where to look to make the correction? I don't know how to edit the add to cart button code.
I am also getting this dynamic attribute file on all my pages...is there anything wrong with this?
<form name="Nitrodog_Checkout_form_1" method="POST" action="<?php echo $_SERVER["PHP_SELF"]; echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>">
<p style="text-align: center">
<input type="image" src="../WA_eCart/Images/Slate/Btn1_EN_checkout.gif" border="0" class="eC_ImageButton" value="Checkout" name="Nitrodog_Checkout_1">
<span style="text-align: center"></span></p>
</form>
it happens in multple pleaces o nthe page.
do a search for:
$ATC_RedirectAfter
it should hightlight that code the first place it is found.
the line directly blow it should be the same, on that second line change:
$ATC_RedirectAfter
$ATC_RedirectIfIn
do a search for the next instance and so on.
