Changing a template that the Framework Builder uses
Thread began 7/03/2013 8:57 am by sandy170299 | Last modified 7/03/2013 10:50 am by sandy170299 | 1170 views | 2 replies |
sandy170299
Scenario: Let's say I created a Dreamweaver Template, and created a Framework Builder Theme from this template. I then created a page called about-us.php. What if I then created a totally different and new template, created a Framework Builder Theme from this template, and wanted to apply this new theme to the about-us.php page instead of the current theme. Can this easily be done? I thought I could simply apply a theme from a list of available themes, but I don't see a way to do that...??? Hope this question makes sense. Thanks!
Open the server behaviors panel, and select the Theme server behavior, then click the minus button to remove it.
Now go to Modify -> Tempaltes -> Detach template.
This will remove the them and template.
you can then attach the new template to the page, Modify -> Templates -> Apply Template. Then add the Theme WebAssist -> Framework builder -> Themes -> Apply Theme
sandy170299
Perfect. Thank you!
