How do I Hide/show if field is empty in jQuery Script
Thread begun 7/02/2013 10:20 am by bhblake | Last modified 7/02/2013 2:52 pm by bhblake | 4719 views | 10 replies |
bhblake
Below is a jQuery code for a product zoom. If the "ProductImage", "ProductLineArt", or "ProductLifestyle"are empty I want to hide the row of code it is listed in...
Please advise:
<a href="<?php echo $row_WADAproduct['ProductZoom']; ?>" class="MagicZoomPlus" id="Zoomer" title="<?php echo $row_WADAproduct['ProductName']; ?> Rug"><img src="<?php echo $row_WADAproduct['ProductImage']; ?>"/></a> <br/>
<a href="<?php echo $row_WADAproduct['ProductZoom']; ?>" rel="zoom-id:Zoomer" rev="<?php echo $row_WADAproduct['ProductImage']; ?>"><img src="<?php echo $row_WADAproduct['ProductSmall']; ?>"/></a>
<a href="<?php echo $row_WADAproduct['ProductLineArtZoom']; ?>" rel="zoom-id:Zoomer" rev="<?php echo $row_WADAproduct['ProductLineArt']; ?>"><img src="<?php echo $row_WADAproduct['ProductLineArtSm']; ?>"/></a>
<?php if($row__WADAproduct['ProductLifestyle'] != "") { ?>
<a href="<?php echo $row_WADAproduct['ProductLifestyleZoom']; ?>" rel="zoom-id:Zoomer" rev="<?php echo $row_WADAproduct['ProductLifestyle']; ?>"><img src="<?php echo $row_WADAproduct['ProductLifestyleSm']; ?>"/></a>
<?php } ?>
use an if statement around each link, for example:
<?php if($row_WADAproduct['ProductZoom'] == "") { ?>
<?php } ?>
bhblake
I put in what you said and I'm getting a syntax error. Please review what i did.
Thank
what is the exact error? it should include a line number.
also send a copy of the page.
bhblake
I just copied the code in again, there is no longer a syntax error, however everything is being hidden.
I attached the page. Thanks again
I dont see anything obvious in the code.
bhblake
Site info sent
at lines 740 - 743:
        <a href="<?php echo $row_WADAproduct['ProductZoom']; ?>" class="MagicZoomPlus" id="Zoomer"><img  src="<?php echo $row_WADAproduct['ProductImage']; ?>"/><?php } ?></a> <br/>
<div id="Design_copyright">Copyright <?php echo $row_WADAproduct['CopyrightName']; ?></div><br />
<?php } ?>
you have an extra closing bracket.
I removed line 743 to correct the problem.
bhblake
I made the same correction and re-uploaded the file.
Originally Said By: bhblake
