Dreamweaver crash
Thread begun 7/01/2013 9:41 am by MMEN76899049 | Last modified 8/29/2013 7:25 am by Jason Byrnes | 4013 views | 7 replies |
MMEN76899049
Dreamweaver crash
Hi! I can´t use Data Assist Pages. Every time I try to use it, Dreamweaver crashes. I tried uninstalling-installing Data Bridge extension, reset dreamweaver configuration folder, hide Files window, disable Preview from Webassiste Preferences, use a minimal table, and always the same result: Crashes on different points after the Search page. The problem is the same for Dreamweaver CS4 and CS6 on Windows 8. Thanks a lot for your help.
in your table the ID column is set to length of 5 bytes:
DROP TABLE IF EXISTS `abc`;
CREATE TABLE `abc` (
`id_abc` int(5) NOT NULL AUTO_INCREMENT,
`fecha` date NOT NULL,
`abc` varchar(255) NOT NULL,
`comentarios` varchar(255) DEFAULT NULL,
PRIMARY KEY (`id_abc`)
) ENGINE=InnoDB DEFAULT CHARSET=utf8;
use 11 insttead:
`id_abc` int(11) NOT NULL AUTO_INCREMENT,
MMEN76899049
Still crashing
Hi, Jason!
I made the changes and still crashing, now after the Detail page
change the date column to be a timestamp instead:
`fecha` timestamp NOT NULL DEFAULT CURRENT_TIMESTAMP ON UPDATE CURRENT_TIMESTAMP,
MMEN76899049
Again
It crashes again, after the insert page
see private message
Vikingbear
Private Message
Hi Jason, I am having the same issue, I have spoken with Ray Borduin on Skype a number of times and we are still working on the issue..
You sent a private message to MMEN76899049 I was wondering if it contained anything that solved the issue for him? if so, could you send me the same details.. Thanks
> Windows8 64bit, 8GB ram, Adobe CC suite
> Deleted cache, remove & reinstall extension, disable preview
..any suggestions greatly appreciated..
Dreamweaver crashing like this is usually an issue with a Memory leak, dreamweaver is not very good at freeing up memory it is not using.
things to try:
-Disable preview
-Close the Files and server behaviors panel before running the wizards
-Restart the OS after deleting the DWQ Cache file.
