Disount Code from a recordset
Thread begun 7/01/2013 8:24 am by jon392819 | Last modified 7/01/2013 12:30 pm by jon392819 | 2402 views | 5 replies |
jon392819
Hi Guys, I amended the discount code to look up a discount voucher value via recordset. I get an undefined variable error.
The code is below. Before I amended the code the voucher was hard coded and checked against a session created when person put in a valid code. Worked fine. To enable the site owner to change these codes on a whim I set up a dataabse table to hold the voucher. I then created a recordset in eCart1_PHP.php and changed the below. I know the variable $discountcode gets the correct value but On the cart page its says undefined. Any help really appreaciated. I have put 3 # sybols in front of and at the end of the code I inserted to help you see what I changed.
function WAEC_eCart1_discountRule() {
$totalDiscount = 0;
#####$discountcode = $row_Recordset1['voucher'];####
if (true && ((sizeof($this->Items) > 0) && ((isset($_SESSION['coupon'])?$_SESSION['coupon']:"") == ###$discountcode###))) {
$totalDiscount += ($this->ConditionalTotal("TotalPrice", "sale", "no") * 0.20);//Result
instead of doing it this way, store the recordset value in a session variable, and use the session variable in the discount rule.
jon392819
Genius, I think I have it. Thanks a million Jason.
jon392819
Hi Jason, one final question, Is it possible to have the precentage (discount) dynamicly set by the user in much the same way they are setting the voucher code (via a recordset which sets a session). I attach a screen shot of the discount rules currently in play. I have it set to 20% but would like to give the user the option to change this via a simple CMS. I can do this but am unsure if I can setup the discount rules to look to a session for the precentage to take off.
Thanks a Million Jason
Jon
yup, you could set the percentage in the database using a decimal:
0.20
for 20%
store that in a session and use the session in the calculation, where you have entered 0.20 use:
$_SESSION['percentage']
Assuming the session is named "percentage" ,instead.
jon392819
That easy!!! Thanks again Jason, thats was the fastest response ever. Slow day at webassist? :)
