Having a problem sending toogle option selections to the cart display and customer / store receipt
Thread begun 6/28/2013 11:26 am by elewis93815 | Last modified 7/01/2013 10:22 am by elewis93815 | 2617 views | 6 replies |
elewis93815
We have created a section of a shopping cart "Small Sandwich Platters" that have several sandwich options.
The customer is allowed to choose up to 4 options of sandwiches and then select add to cart. The sandwich options are listed, however, they are not showing in the order display. The "Large Sandwich Platter" which is a section I worked on some time ago with Jason or Ray works just fine with the sandwich options showing in the description section of the order display. I'm just having trouble getting the "Small Sandwich Platter" to display. I have attached the relevant files to this post. Any direction would be greatly appreciated.
1) The checkboxes for the small sandwich platter are named:
Sandwiches[]2
that needs to be changed to:
Sandwiches2[]
2) the add to cart code for the small platter is at lines 345 - 380:
// WA eCart AddToCart
if (isset($_POST["cupcake1_13_ATC"]) || isset($_POST["cupcake1_13_ATC_x"]))     {
$ATC_itemID $_POST["cupcake1_13_ID_Add"];
$ATC_AddIfIn 0;
$ATC_RedirectAfter "order_display.php";
$ATC_RedirectIfIn  "";
  if (isset(
$totalRows_rsCaterLunch) && $totalRows_rsCaterLunch 0)     {
$row_rsCaterLunch WAEC_findRecordMySQL($rsCaterLunch"PRODUCTID"$ATC_itemID);
    if (
$row_rsCaterLunch)     {
$ATC_itemName "Small Sandwich Platter";// column binding
$ATC_itemDescription "";// column binding
$ATC_itemWeight floatval("0");// column binding
$ATC_itemQuantity "".$_POST["cupcake1_13_Quantity_Add"]  ."";// column binding
$ATC_itemPrice floatval("34.95");// column binding
$ATC_itemPlatterOptions "";// column binding
$ATC_itemTaxable "1";// column binding
mysql_data_seek($rsCaterLunch0);
$row_rsCaterLunch mysql_fetch_assoc($rsCaterLunch);
$ATC_itemQuantity floatval($ATC_itemQuantity);
  if (
is_numeric($ATC_itemQuantity) && $ATC_itemQuantity != 0)     {
$cupcake1->AddToCart($ATC_AddIfIn$ATC_RedirectIfIn$ATC_itemID$ATC_itemName$ATC_itemDescription$ATC_itemWeight$ATC_itemQuantity$ATC_itemPrice$ATC_itemPlatterOptions$ATC_itemTaxable);
    if (
$ATC_RedirectAfter != "" && $cupcake1->redirStr == "")     {
$cupcake1->redirStr $ATC_RedirectAfter;
    if (isset(
$_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "")  {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF']."?".$_SERVER['QUERY_STRING'];
    else  {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'];
line 360 sets the options:
$ATC_itemPlatterOptions = "";// column binding
change that to:
$ATC_itemPlatterOptions = "".((isset($_POST["Sandwiches2"]))?implode(", ",$_POST["Sandwiches2"]):"")  ."";// column binding
elewis93815
Thank you Jason! I have updated line 360 as well as changed the Sandwiches[]2 to Sandwiches2[] and the sandwich options are still not showing???? i've attached the new files after the recent changes.
the checkboxes are a part of a seperate form from the add to car buttons.
change:
<form name="cupcake1_13_ATC_<?php echo $row_rsCaterLunch["PRODUCTID"]; ?>" method="POST"  action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""?>">
                        <input type="hidden" name="cupcake1_13_ID_Add" value="<?php echo $row_rsCaterLunch["PRODUCTID"]; ?>" >
                        <input type="text" name="cupcake1_13_Quantity_Add" value="1" size="4" >
                        <input type="submit" class="eC_FormButton" value="Add to Cart" name="cupcake1_13_ATC">
                      </form>
                      <form  action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""?>" method="post" name="cupcake1_11_ATC_<?php echo $row_rsCaterLunch["PRODUCTID"]; ?>" id="cupcake1_11_ATC_<?php echo $row_rsCaterLunch["PRODUCTID"]; ?>2">
                        <br />
                        <table width="400" border="0" cellspacing="0" cellpadding="0">
                          <tr>
                            <td width="45"><input type="checkbox" name="Sandwiches2[]" value="smoked Turkey" /></td>
                            <td width="355">Smoked Turkey</td>
                          </tr>
                          <tr>
                            <td><input type="checkbox" name="Sandwiches2[]" value="BLT" /></td>
                            <td>BLT</td>
                          </tr>
                          <tr>
                            <td><input type="checkbox" name="Sandwiches2[]" value="Tuna Salad" /></td>
                            <td>Tuna Salad</td>
                          </tr>
                          <tr>
                            <td><input type="checkbox" name="Sandwiches2[]" value="Club" /></td>
                            <td>Club</td>
                          </tr>
                          <tr>
                            <td><input type="checkbox" name="Sandwiches2[]" value="Brie and Apple" /></td>
                            <td>Brie and Apple</td>
                          </tr>
                          <tr>
                            <td><input type="checkbox" name="Sandwiches2[]" value="Pesto" /></td>
                            <td>Pesto</td>
                          </tr>
                          <tr>
                            <td><input type="checkbox" name="Sandwiches2[]" value="Hummus Wrap" /></td>
                            <td>White Bean Hummus Wrap</td>
                          </tr>
                        </table>
                      </form></td>
                  </tr>
                </table>
                        <br />
                          <tr>
                          </tr>
                          <tr>
                            <td>BLT</td>
                          </tr>
                          <tr>
                            <td>Tuna Salad</td>
                          </tr>
                          <tr>
                            <td>Club</td>
                          </tr>
                          <tr>
                          </tr>
                          <tr>
                            <td>Pesto</td>
                          </tr>
                          <tr>
                          </tr>
                        </table>
                      </form></td>
                  </tr>
                </table>
elewis93815
Sorry, but can you tell me where this code starts and stops. I did a find on this code and it's not finding it. Thanks!
you just need to delete lines 765 - 766:
</form>
elewis93815
Thank you Jason! Issue solved! Have a wonderful day!
