Dreamweaver CC Compatibility
Thread begun 6/25/2013 6:40 am by Jason Byrnes | Last modified 7/09/2015 1:49 pm by Ray Borduin | 12307 views | 19 replies |
In the Download center, a ZXP Version of Design Extender is available to install into Dreamweaver CC.
Before installing the Design Extender ZXP Extension, make sure you have installed the Deprecated Server Behaviors extension that Adobe has made available, see this tutorial for details:
http://www.webassist.com/community/tutorials/view_tutorial.php?tid=233
While installing the extension on Mac OS, you may encounter an Error stating:
"Failed to update database, the extension will not be installed"
This is a bug in the CC Extension manager that will be corrected by Adobe soon, The extension has, in fact, been installed and can be accessed through the menus in Dreamweaver.
Gizza372666
DataBridge
Hi Jason,
I just installed Dreamweaver CC and databridge but there is a number of issues,
1) when I try to run HTML Editor I receive error2 ?(The following JavaScript error(s) occurred: Unable to open script file "C:\Program Files (x86)\Adobe\Adobe Dreamweaver CC\Configuration\Objects\Forms\formInsert.js" (error 2).
2) The only icons are on show under the WebAssist tab are: filemanager (error 3 every time I select the icon), Repeating Table (error 3 every time I select the icon), Insert Dynamic Web Chart, css button (error 2), Captcha (error 2), Data picker (error 2), Validation Show if, Resized image, css form,
Gizza372666
cookies, Text Editor,
Error 3 = The following JavaScript error(s) occurred: Unable to open script file "C:\Program Files (x86)\Adobe\Adobe Dreamweaver CC\Configuration\Objects\Server\serverObjectsCommon.js" (error 3).
my OS is Windows 7 ultimate 64bit.
I tried on both my pc and laptop and I have the same error messages. I installed all the disabled extensions from Dreamweaver, installed Databridge, deleted the WinFileCache file, reset my workspace and the issues is still there.
I uninstalled the extensions and then reinstalled them and the issue is still there.
Please help!
adobe unexpectedly removed the Configuration\Objects\Forms\ folder in a recent update.
here is a copy of the Configuration\Objects\Forms\ folder to add to your users configuration folder.
for details on locating the users configuration folder, see the following tutorial:
The other errors sound like the Server Behaviors extensions has not been installed, make sure to install the depreciated server behaviors extension:
Gizza372666
HI Jason, what do you mean by saying:
"here is a copy of the Configuration\Objects\Forms\ folder to add to your users configuration folder."?
I created a new folder called Forms within the Objects folder but the issue is still there.
I cleared the cache, installed the Server Behaviors and the issue is not fixed.
can you please clarify?
sorry, forgot to attach the Objects\Forms folder
Gizza372666
Hi Jason, the majority of the databridge ext now work thanks.
Can you please let me know how to display the icons onto the webassist insert tab as I don't have them all?
What icons do you think are missing?
Gizza372666
data assist, security assist and data assist search
those are not insertable behaviors, they are wizards.
to access the data assist wizard go to WebAssist -> Database -> DataAssist pages.
to access the Databases Search wizard, go to WebAssist -> Database -> Database Search Wizard
to access the Security Assist wizard, go to WebAssist -> Security Assist -> Create Security Assist Pages.
