jpgs not showing
Thread begun 6/25/2013 3:36 am by Jamie | Last modified 6/25/2013 9:43 am by Jason Byrnes | 4669 views | 10 replies |
Jamie
jpgs not showing
Hey Jason
No sure what is going on here but as you can see from the 2 attached screengrabs, images that should be showing arent and I cant figure out why that would be.
In the image 'gallery.jpg' you can see the results page which isnt showing any images, but the individual detail page is showing the correct image....
in the 'blog.jpg' image you can see that there should be a tick or a cross where the arrow is pointing
Any ideas what I could be doing wrong? If you need any files or access just let me know and will fire it over to you
Cheers
Jamie
it is impossible to troubleshot design related issues from a screen shot.
Jamie
thanks Jason see PM
Originally Said By: Jamie
  thanks Jason see PM
Jamie
oops
  oops
Jamie
in test/css/admin.css
this css causes the problem:
#results img {
visibility:hidden;
Jamie
as ever Jason... you're a legend! many thanks
Jamie
Jamie
with the same installation Jason, why would i be getting these at the login screen and not being able to login:
Warning: Cannot modify header information - headers already sent by (output started at /home/motle8wh/public_html/clients/test/WA_CMS/WA_CMS.php:56) in /home/motle8wh/public_html/clients/test/admin_cms/users_login.php on line 49
Warning: Cannot modify header information - headers already sent by (output started at /home/motle8wh/public_html/clients/test/WA_CMS/WA_CMS.php:56) in /home/motle8wh/public_html/clients/test/admin_cms/users_login.php on line 52
