CROP FROM CENTER
Thread begun 6/24/2013 9:51 pm by Cologne | Last modified 7/10/2013 10:21 pm by Cologne | 3488 views | 5 replies |
Cologne
CROP FROM CENTER
please ad CROP FROM CENTER to the DFP!!!
Just like in the Image Resizer!
This is so important.
Thanks!
Denis
I will add a feature request.
In actual fact though, if you are using DFP to create multiple version of the same image, we suggest using Image resizer instead. Image resizer gives more flexibility.
Cologne
OK, thanks!
Cologne
Hi Jason,
the problem is, that when you change the image (rotation etc.) it wont get updated.
Cheers,
Denis
if the image file name is the same, it will have no way of knowing that a change has been made, you would need to delete the cached image to have it regenerated.
Cologne
So the Trick is, delete After Rotation is done.
Thanks a Lot!
