array(0) { }
Thread begun 6/24/2013 3:16 pm by Paul | Last modified 6/28/2013 9:10 am by Paul | 1619 views | 2 replies |
Paul
array(0) { }
I've been successfully building the site in my localhost, including the DA Admin section. Today I uploaded it to the webserver and I'm getting a few errors in the admin section, although the products are being updated.
I saw that once I uploaded the admin pages to the webserver, the images that I had on the localhost were not showing up. the _3.jpg or _7.jpg were not in the Product_images folder. Realizing that I don't need to have DA make new images, but replacing was good enough, I changed the page and uploaded to the server.
Now, when I go to the products_insert.php page, I see this: array(0) { } at the top of the page. Updating information and adding new images works fine though.
Once I click "UPDATE", it reloads the page with this at the top:
array(2) { ["prodThumb"]=> array(5) { ["name"]=> string(8) "1555.jpg" ["type"]=> string(10) "image/jpeg" ["tmp_name"]=> string(25) "/tmp/phpuploads/phpqIyewM" ["error"]=> int(0) ["size"]=> int(63822) } ["prodImage"]=> array(5) { ["name"]=> string(8) "1555.jpg" ["type"]=> string(10) "image/jpeg" ["tmp_name"]=> string(25) "/tmp/phpuploads/phpKwKEha" ["error"]=> int(0) ["size"]=> int(63822) } } Warning: Cannot modify header information - headers already sent by (output started at /webroot/c/e/centu002/primary/www/admin/products_update.php:5) in /webroot/c/e/centu002/primary/www/admin/products_update.php on line 131
The images show up perfectly on the results page, as well as the details page although. I don't have any problems on the insert page.
Any thoughts?
remove the following at lines 4 - 6:
if(isset($_FILES)) {
var_dump($_FILES);
Paul
Sorry I didn't reply quicker, Jason...but this worked.
Thanks again!
