Does eCart Work with Dw CC?
Thread begun 6/24/2013 1:55 pm by M2Media | Last modified 8/26/2013 7:47 am by M2Media | 5404 views | 12 replies |
M2Media
Earlier eCart was working fine with Dreamweaver CS6; does it work with Dreamweaver CC, yet?
yes, there is an update in the Download center for compatibility with Dreamweaver CC.
M2Media
The attached message is what I see when I attempt to install it.
M2Media
As attached, I got further on a second try but it didn't do the whole job.
That is a bug in the CC Extension manager, the extension has actually been installed and is accessible from the menus in dreamweaver, see this thread for details:
http://www.webassist.com/forums/posts.php?id=31583
M2Media
You are 100% correct. Thank you very much.
Is there an eCart PDF manual?
there is not a pdf manual.
all of the eCart documentation can be found on the eCart support page:
ecart
M2Media
Attempting to choose any object, as attached, attempts to open the following in Safari: file:///Volumes/Winnie/Users/winnie/Library/Application%20Support/Adobe/Dreamweaver%20CC/en_US/Configuration/Shared/WebAssist/eCart/Help/index.htm#using_ecart/02_Add/ec_ac_01.htm
make sure you are using the Add Cart button under the list of cart objects, not the add an ecart object help link.
see the attached screen shoot.
M2Media
AH HA! Once I roll over the eCart graphic a tool tip says "Help." Since I didn't wait dot he tool tip, I had no idea. Thanks.
