Quantity discounts based on same item
Thread begun 6/24/2013 2:03 am by markdoyle87077 | Last modified 6/25/2013 11:47 pm by markdoyle87077 | 2883 views | 6 replies |
markdoyle87077
I am trying to implement quantity discounts based on the number of the same item ordered. I can see that I can apply a discount based on the quantity of a specific item in the cart but as I understand it I would have to provide the specific item number. I want this to work across the whole site (roughly 4000 products) so the customers can get a discount for buying 5 and 10 of the same product. To do this using the quantity of a specific item in the cart trigger would require 4000 rules. Could you kindly point me in the right direction? This is a customer request for an ASP site.
Many thanks.
you would need to have a Cart column for the category and store the category in that column using the add to cart buttons.
instead of using a calculation for this, you would use a discount rule on the discounts tab.
Set the trigger to:
"Number Of Items with A Specific Column value"
if the number of items where "category" has a value of "category name" is ">=" a value of "3"
and in the calculations section, use:
"Based on items with a specific value"
Total of "Total Price" where "category" has a value of "category name" "times" "0.10"
markdoyle87077
Discounts
Set the trigger to:
Hi Jason,
I have set that up but it does not work how I want it to. I have set the rule to look at the VolumeDiscount column in eCart and then give 10% discount if there are 3 of more of the VolumeDiscount category in the cart. See attachment: rule.
This works fine, see attachment: invoice. Both items have the same VolumeDiscount and they total up to 3 and the discount is applied.
What I want to happen is that the discount is only applied if a single or multiple rows meets the rule so in the attachment: invoice if 43956 was set to quantity 3 and 79700 was set to 1 I would like the rule to work for row 43956 and apply 10%. Equally if both 43956 and 79700 where set to quantity 3 then the rule would apply discounts for both rows.
Maybe the rule has to calculate based in a unique ID and VolumeDiscount, only guessing here..
Hope you follow.
Many thanks.
So the discount should only apply to an item in the category if the quantity is 3 or more.
OK, so that has to go back to the calculation method.
[Price] - ((Abs([Quantity]>=3 && [VolumeDiscount] == 7)*[Price]*0.1)
markdoyle87077
Discounts
Hi Jason,
I have set the following that you supplied to TruePrice, ss that correct
and then I changed TotalPrice to:
([Price] - ((Abs([Quantity]>=3 && [VolumeDiscount] == 7)*[Price]*0.1)) * [Quantity]
As a result I now get this:
Microsoft VBScript compilation error '800a03ea'
Syntax error
/dmbc/WA_eCart/dmbp_VB.asp, line 320
itmObj.TotalPrice = (itmObj.Price - ((Abs(itmObj.Quantity>=3 && itmObj.VolumeDiscount == 7)*itmObj.Price*0.1)) * itmObj.Quantity'c
My end goal here is to have 3 different order quantities that will result in the following discounts for VolumeDiscount = 7, is it possible to evaluate 2 or more VolumeDiscounts in this calculation or not
3 +- 10%
10+ - 15%
20+ - 20%
Sorry, you did not specify this was ASP, I thought it was PHP
in ASP
should be:
AND [VolumeDiscount] = 7
to have multiple break points, you need multiple conditions:
((Abs([Quantity]>=3 AND [Quantity]<=9 [VolumeDiscount] = 7)*[Price]*0.1) + ((Abs([Quantity]>=10 AND [Quantity]<=19 [VolumeDiscount] = 7)*[Price]*0.15) + ((Abs([Quantity]>=20 AND [VolumeDiscount] = 7)*[Price]*0.2)
markdoyle87077
Discount based on Quantity
Hi Jason,
I will have a play around now I know how the format works. I will come back to you if I hit any problems but I am fairly confident that I can proceed.
Yet again, superb support, totally unrivalled.
