Failed Install of DataBridge foe Dreamweaver CC
Thread begun 6/22/2013 5:36 pm by Lee Firth | Last modified 7/08/2013 11:11 am by Marga-NL | 6488 views | 12 replies |
Lee Firth
Failed Install of DataBridge for Dreamweaver CC
I have just tried to install the new DataBridge extension for Dreamweaver CC (the zxp file), I got an error message that said "Failed to update database. The extension will not be installed."
Mike
Same error
mousework50137
same here, with ecart 5, design extender and data bridge, none will install
greeboss
Same here. Running Mac and DW CC. Cant install the CC-extensions.
jbeckman307551
Design Extender installed but not the other two
Oddly, I got Design Extender to install, but the other two come up wit this same error.
For anybody reporting this issue, please report back with your Operating System version so we can look into the cause.
buchbay350666
OSX 10.8.4
Looks like this is a bug with the CC Extension Manager on Mac OS.
If you open DW, you should see that the extension is actually installed. I tested with eCart and got the same error, but opening DW, eCart was under the Insert -> WebAssist menu and was functional.
This issue is happening for other extensions as well, not just ours, there are a few threads about it on the Adobe forums, the Project 7 Forums, and DMX Zone forums.
jbeckman307551
Well, yes, all the items appear in the menus, but they don't seem to work. Everything I try craps out with missing files/paths or just pops on the screen for a second and vanishes.
My OS is OS X 10.8.4.
you have to install the Deprecated Server Behaviors extension. Also make sure to define the Database connection before starting the wizards.
You will also need to add the Configuration/Objets/Forms folder.
see this thread for details:
http://www.webassist.com/forums/posts.php?id=31581
