Error Message when add to cart button
Thread begun 8/14/2009 2:19 pm by Jasmalb327457 | Last modified 8/14/2009 4:20 pm by Jason Byrnes | 1666 views | 1 replies |
Jasmalb327457
This is the message that I get,
I need help critically!!!! i HAVE A SITE THAT MUST BE RUNNING BY TOMMORROW MORNING!!!
Warning: require_once(../../../WA_eCart/Customecart_PHP.php) [function.require-once]: failed to open stream: No such file or directory in D:\Hosting\4719347\html\ecartstore\store_static_sp_php\store_static_sp_php\store_php\cart.php on line 3
Fatal error: require_once() [function.require]: Failed opening required '../../../WA_eCart/Customecart_PHP.php' (include_path='.;C:\php5\pear') in D:\Hosting\4719347\html\ecartstore\store_static_sp_php\store_static_sp_php\store_php\cart.php on line 3
Also when I try and USE CHECKOUT WIZZARD
While executing onLoad in WA eCart Checkout WIZARD.htm, the following Java script errors occured:
In File "WA eCart CheckoutwIZARD
INITIALIZE ui IS NOT DEFINED
SARAH ALBRIGHT
the require once line:
on a page at:
D:\Hosting\4719347\html\ecartstore\store_static_sp _php\store_static_sp_php\store_php\cart.php
would be looking for the WA_eCart/Customecart_PHP.php file 3 directories below its curant location:
D:\Hosting\4719347\html\ecartstore\WA_eCart/Customecart_PHP.php
make sure the eCart directory is being uploaded to:
For the other error, try deleting the cache file in the users configuration folder. You can find more details in the "Common Installation Issues" pdf file that is linked on the right hand side of the download center:
