CSS Help
Thread begun 6/21/2013 4:59 am by Daniel | Last modified 6/24/2013 2:07 pm by Jason Byrnes | 4206 views | 9 replies |
Daniel
CSS Help
Hi there
I'm not sure as to why this is doing it. I saved my index.php page as listen-now.php with the same css style. How ever when I go from the index page to the listen-now page the nav size is not the same?
Any idea on why this is doing it?
Daniel
http://www.justvibe.co.uk
http://www.justvibe.co.uk/listen-now.php
on the first page, you set the font family for the body tag:
body {
background-color: #333333;
font-family: Arial,Helvetica,sans-serif;
on the second page you dont:
body {
background-color: #000000;
background-image: url("../images/bg.gif");
background-repeat: repeat-x;
font-size: 100%;
line-height: 1.6;
margin: 0;
padding: 0;
text-decoration: none;
add the font family to the body tag:
Daniel
HI Jason
I have done that but its still doing the same?
in the CSS File:
http://www.justvibe.co.uk/assets/css/listen-now-style.css
the CSS For the body tag:
body  {
background-image : url(../images/bg.gif);
background-color : #000;
background-repeat : repeat-x;
margin : 0;
padding : 0;
line-height : 1.6;
text-decoration : none;
font-size : 100%;
font-family : "Chaparral Pro", "Palatino Linotype", "Book Antiqua", "Palatino, serif",;
uses a different font family listing, that, and the listing is not formatted correctly.
Daniel
Hi Jason. I understand that however I have look at the css file im uploading and the body css are the same.
any idea?
what css file are you uploading?
the page is using the:
file, so you need to make the change in that file.
if you are changing and uploading that file, then the upload is not working.
Daniel
please see above attached image.
on the index page, though, the http://www.justvibe.co.uk/assets/css/twitter-styles.css file is overriding the font family to Arial,Helvetica,sans-serif;
Daniel
Thanks Jason. That seams to have done it. I just moved the <link href="assets/css/twitter-styles.css" rel="stylesheet" type="text/css" /> to above the css for the twitter.
Could you have one last check you end to make sure?
yes, they look the same now.
