DataAssist Search Comparisons
Thread begun 6/18/2013 6:05 am by stephen287384 | Last modified 6/19/2013 8:02 am by Jason Byrnes | 1863 views | 3 replies |
stephen287384
I have 2 search fields, one for keywords and the other for areas (suburb or postcode). They are both set to keyword and "includes" and "=" respectively.
I have 2 problems:
1. i want users to be able to search using either or both of the fields, eg: widgets Melbourne OR just Widgets OR just Melbourne.
2. Currently if a user searches for eg: camera melbourne the results are correct BUT if the user searches for eg: cameras melbourne there are NO results. I have tried "begins with" which does not work as the database records are eg: Nikon Digital Camera, so it would look at Nikon first and fail. I have tried changing the first filed to "includes" which only works for camera NOT cameras.
1) if the user only fills in one field the other filed will not be included in the search. the other field will be ignored.
it sounds like you should use the OR seperator for your needs between the 2 keyword search criteria.
2) That is the way it is supposed to work.
the string "cameras" is not contained in the column "Nikon Digital Camera" so nothing is returned.
the includes criteria looks at each word:
cameras = Nikon | NO
cameras = Digital | NO
cameras = Camera | NO
so no result is returned when searching for cameras
a result is returned for camera because that is a word in the column:
camera = Nikon | NO
camera = Digital | NO
camera = Camera | YES
stephen287384
When i change the second comparison to OR and search for camera it shows ALL database results.
//comparison list additions
$WADbSearch1->keywordComparison($KeyArr1,"".((isset($_POST["what"]))?$_POST["what"]:"") ."","AND","Includes",",%20","%20","%22","%22",0);
$WADbSearch1->keywordComparison($KeyArr2,"".((isset($_POST["area"]))?$_POST["area"]:"") ."","OR","=","%20AND%20","OR","%22","%22",0);
If a user was looking for a camera, they would most likely search for cameras, eg: "Digital Cameras", is there any way around this other than changing the records? Listing an item as eg: "Nikon D700 Digital Cameras" for a single camera would not be sensible.
I just did a Google search for "cameras" and both "camera" AND "cameras" came up in the results. How do they achieve this? Do they have a database column containing all keywords assosiated with the product?
Also i want it to work on EITHER or BOTH fields as some users would just search camera, other users would search for camera and the area. Is this possible?
OK, I guess I'm not clear on what was wrong when you had the second criteria set to AND.
if when using and for both, it should ignore the criteria if you leave it empty. It should only e part of the search if you enter a value.
as for the google search, a well designed web site will have a keywords meta tag for each page. The web site developer will add a keywords list to this meta tag that should return the page. So in the case of searching for cameras the keywords meta tag would contain both cameras and camera:
<meta name="keywords" content="cameras, camera">
you could create a similar column in your database and use that column in the search rather than the item name column.
