Rotate Image After Upload
Thread begun 6/17/2013 1:43 pm by Cologne | Last modified 9/11/2013 12:11 am by arron | 1205 views | 2 replies |
Cologne
how can I rotate the image after uploading and restore it?
This should be for my users whio upload images that are not in the right view.
I found that http://php.about.com/od/gdlibrary/ht/imageroatephp.htm looks good but I dont know how to use it.
users see their image and I want a little button "turn 90 to the right. If button is pressed it should turn the image and restore it.
Cheers,
Denis
This is not supported in the Image Upload behavior, it is supported in the HTML Editor File Manger though.
If you use a file manager instance, the file manager allows for image rotate, otherwise, it would require hand coding.
arron
Hi, I am a newbie here. I used to rotate images using some simple code with the help of some manual tools. But I don't know how to add code here. You can also google some manual tool to help you rotate images and customize it according to its programming guides. I hope you success. Good luck.
Best regards,
Arron
