file upload name
Thread began 6/17/2013 9:39 am by Ashok | Last modified 6/17/2013 10:50 am by Jason Byrnes | 909 views | 3 replies |
Ashok
file upload name
I am uploading a file with update wizard and want to rename the file as project name (on re upload with increment). The database shows original file name but the file is renamed. Is it ok for db to show the original file name?
The page is attached.
In the Update record behavior, you have bound the material column to the material file field.
instead us the Uploaded Files(material) -> Server File Name binding.
Ashok
I am still not getting it.
Bind in both "File" and "Default File" fields?
no, that is the File Upload behavior.
No edit needs to be done for the file upload behavior. the change needs to be done in the Insert and Update record behaviors.
