Chechbox size options - Confused
Thread begun 6/14/2013 11:12 am by FrankJay | Last modified 6/17/2013 8:48 am by Jason Byrnes | 5028 views | 7 replies |
FrankJay
I have read most of the forum posts and tutorials about checkbox options for eCart. Particularly, Product Options with eCart and Checkbox method for add to cart. I have gained some knowledge to understand how this functions. Unfortunately, none of the above match exactly what I need to achieve and with my limited knowledge of coding I am pretty much confused. Trying to cut and paste from a variety of posts is certainly not my speciality.
I have used dataAssist to generate my back end pages for the clothing. On my clothing details page I have the main recordset using a URL parameter for the ID which works well and I'm able to display all the clothing information I need.
My second recordset is for the size options that I would like to display using checkboxes/checkbox group. It is here that I am stumped.
I have successfully managed to get e-cart to work properly except for the checkbox size options.
I only have one option for the option group, namely: product sizes. Some in age, some in measurement and some in size.
I have three tables for the above functionality:
ssProductClothing,
ss_ClothingID
ss_ClothingName
ss_ClothingImage
ss_ClothingSizeGroup
ssSizeGroups,
ss_SizeGroupID
ss_SizeGroupName
ssSizes
ss_SizeID
ss_SizeGroupParentID
ss_SizeName
I specifically need step for step help (as I have never done this before) to add checkboxes that hold information from the size recordset.
Then I need to know how to filter this recordset to pass only the values of the sizes that the visitor has selected. ( not sure if must use the web assist search wizard to accomplish this - never used it before)
Here is the code for 2 recordsets on the detail page:
$colname_rsSchoolwearDetails = "-1";
if (isset($_GET['ClothingDetails'])) {
$colname_rsSchoolwearDetails = $_GET['ClothingDetails'];
mysql_select_db($database_connSSlist, $connSSlist);
$query_rsSchoolwearDetails = sprintf("SELECT ssProductClothing.ss_ClothingID, ssProductClothing.ss_ClothingCode, ssProductClothing.ss_ClothingName, ssProductClothing.ss_ClothingImage, ssProductClothing.ss_ClothingImageTitle, ssProductClothing.ss_ClothingColour, ssProductClothing.ss_ClothingSizeGroup, ssProductClothing.ss_ClothingOuterPackaging, ssProductClothing.ss_ClothingInnerPackaging, ssProductClothing.ss_ClothingComposition, ssProductClothing.ss_ClothingPrice, ssProductClothing.ss_ClothingPromote, ssProductClothing.ss_ClothingStatus, ssColours.ss_ColourName, ssSizes.ss_SizeName, ssPackagingOuter.ss_PackagingQuantity, ssPackagingInner.ss_InnerContent, ssFabricComposition.ss_CompositionContent FROM ssProductClothing INNER JOIN ssColours ON ssProductClothing.ss_ClothingColour = ssColours.ss_ColourID INNER JOIN ssSizes ON ssProductClothing.ss_ClothingSizeGroup = ssSizes.ss_SizeGroupParentID INNER JOIN ssPackagingOuter ON ssProductClothing.ss_ClothingOuterPackaging = ssPackagingOuter.ss_PackagingID INNER JOIN ssPackagingInner ON ssProductClothing.ss_ClothingInnerPackaging = ssPackagingInner.ss_InnerID INNER JOIN ssFabricComposition ON ssProductClothing.ss_ClothingComposition = ssFabricComposition.ss_CompositionID WHERE ssProductClothing.ss_ClothingID = %s AND ssProductClothing.ss_ClothingPromote = 0 AND ssProductClothing.ss_ClothingStatus = 1", GetSQLValueString($colname_rsSchoolwearDetails, "int"));
$rsSchoolwearDetails = mysql_query($query_rsSchoolwearDetails, $connSSlist) or die(mysql_error());
$row_rsSchoolwearDetails = mysql_fetch_assoc($rsSchoolwearDetails);
$totalRows_rsSchoolwearDetails = mysql_num_rows($rsSchoolwearDetails);
$paramItem_rsSizes = "-1";
if (isset($row_rsSchoolwearDetails['ss_ClothingSizeGroup'])) {
$paramItem_rsSizes = $row_rsSchoolwearDetails['ss_ClothingSizeGroup'];
$query_rsSizes = sprintf("SELECT * FROM ssSizes WHERE ssSizes.ss_SizeGroupParentID = %s", GetSQLValueString($paramItem_rsSizes, "int"));
$rsSizes = mysql_query($query_rsSizes, $connSSlist) or die(mysql_error());
$row_rsSizes = mysql_fetch_assoc($rsSizes);
$totalRows_rsSizes = mysql_num_rows($rsSizes);
Thanks in advance for your much-needed assistance
see this tutorial for details on working with options:
http://www.webassist.com/community/tutorials/view_tutorial.php?tid=63
This tutorial is geared towards using Select Lists. Using Checkboxes would not be a good idea since that would allow for multiple options to be selected, you could covert the select list to a radio group though if you like.
the key is to make sure that select or radio buttons pass the selected ID, you then use the form element post for the lookup recordset to lookup the selected option.
FrankJay
thanks Jason,
I too have read this tutorial. I need the checkbox size option for all the available sizes per product. These must be listed on the details page. The visitor has the option to select one or more of the available sizes that needs to be added to the shopping cart.
please advise further
That is not supported by eCart.
It would take extensive custom coding for this to work.
if you need assistance implementing this, i suggest signing up for a premiere support appointment.
FrankJay
Will first need to wait for some payment
Thanks Jason
Premiere support is $99 / 30 minutes of One on one development time.
sign up here:
http://www.webassist.com/premier_request.php
FrankJay
New Message
We can probably complete this in a 30 minute session, but it may take a second session. It depends on a number of things.
If you put through the request we can get back to you with specific scheduling:
