filter data range with datepicker (german date format)
Thread begun 6/14/2013 6:05 am by info4753 | Last modified 6/14/2013 1:34 pm by Jason Byrnes | 6448 views | 6 replies |
info4753
I try to filer a data range with two datepickers with the following date format: dd.mm.yyyy
I can't find a way to filter the records in the MySQL database correctly. Where do I have to reformat the date from dd.mm.yyy to yyyy-mm-dd?
The fields look like this:
<input id="DatumVon" name="DatumVon" type="text" value="<?php echo((isset($_GET["DatumVon"])?$_GET["DatumVon"]:"")); ?>" class="formTextfield_Medium" tabindex="2" onBlur="hideServerError('fieldset_group_ServerError_2');" placeholder="<?php echo $today; ?>">
<input id="DatumBis" name="DatumBis" type="text" value="<?php echo((isset($_GET["DatumBis"])?$_GET["DatumBis"]:"")); ?>" class="formTextfield_Medium" tabindex="3" onBlur="hideServerError('fieldset_group_ServerError_2');" placeholder="<?php echo $dayInOneWeek; ?>">
DB-Select is:
SELECT *
FROM res_datum
WHERE Datum BETWEEN param1 AND param2
ORDER BY Datum ASC
param1 is DatumVon
param2 is DatumBis
Thanks for any help?
put the following code at line 1 to convert the entered date to yyyy-mm-dd H:i:s format
if(isset($_GET["DatumVon"])) $_GET["DatumVon"] = date("Y-m-d H:i:s"strtotime($_GET["DatumVon"]));
if(isset(
$_GET["DatumBis"])) $_GET["DatumBis"] = date("Y-m-d H:i:s"strtotime($_GET["DatumBis"]));
info4753
Thx Jason, I'll give it a try.
info4753
That worked thanks Jason. Now I'm stuck with some dates I've created to use as a start date when the page loads
$today = date('d.m.Y', strtotime("today"));
$dayInOneWeek = date('d.m.Y', strtotime("+7 day"));
How do I convert them to filter the recordset? Thanks for any help in advance.
in the date function, change the format code:
'd.m.Y'
'Y-m-d H:i:s'
info4753
Thx Jason.
Is there a way to show the initial date (placeholder) as 12.06.2013 and filter the recordset as 2013-06-12 in the background like I do with the GET parameter?
you would need to pass it as an additional get parameter.
