Shipping Quote Failed - No Packages to Ship
Thread begun 6/13/2013 3:57 pm by Jared Lui | Last modified 6/27/2013 7:19 am by Jason Byrnes | 3610 views | 11 replies |
Jared Lui
No Packages to Ship
FedEX:
Full Request:
Full Response:
I've read several posts saying this is due to no or zero (0) weights in the DB. I have verified that there are weights in every product, then double checked.
I have no clue what version of eCart this client is using but am assuming due to the age of the files it's version 3 (2008 ish).
I have edited the new file (WA_eCart_FedEx_PHP.php) Jason directed me to download.
I have also received the production key registration email from FedEx with the Key, Account, Password and Meter number and double verified that with FedEx techs.
After I send this I will go through the DB again to triple check the weights and will even go through the products in the admin to check to make sure there are no spaces or anything weird I am missing. Is there anything else to check?
I am jumping into this old site cold after another developer abandoned the client and the client is totally in the dark. And I have only used eCart once and have a learning curve myself.
NOTE: I did see this in the ZIP file I got from WebAssist this line: $FedEx_Server = "https://wsbeta.fedex.com:443/web-services/rate";
Is this correct? In the email from FedEx I was given this production URL https://ws.fedex.com:443/web-services. Is there a place where I need to verify the production URL?
Thanks in advance!
Jared Lui
Sent private reply. Thanks.
Originally Said By: Jared Lui
Jared Lui
See private response
I Dont know where fed ex is getting that response from, but if I tri to dump the reult of the CURL post to fed ex, i get the following:
ERRORERRORprof1000Authentication Failedcrs1000
Jared Lui
Yeah. They insist that they are getting everything and sending it back and all of my settings are correct. So I give up and will start from scratch next week and build a new cart using #5.
Question: can I use the current database or should I create a new one and start 100% from scratch?
You should be able to use the existing database, no need to scratch that.
Jared Lui
Cool. Thank you sir!
BruceT
Same problem
I'm getting the same error message but there are weights assigned to every product in the catalog.
I contacted FedEx and they told me PowerStore is pinging their testing server rather than their production server. I've verified that the "Test Mode" check box is unchecked... twice. I've also verified that I'm using their production code rather than their test code.
I accidentally tried running the shopping cart checkout the first time around with the FedEx production code in place, while the cart settings were still in test mode. I'm wondering if that didn't populate the relevant field with the test information and that field isn't reverting to the unchecked status as a result.
