MySQL connection problems
Thread begun 8/14/2009 11:13 am by martistott342331 | Last modified 2/28/2017 8:39 am by Ray Borduin | 7515 views | 28 replies |
martistott342331
I am using a PHP/MySQL system, and Dreamweaver 8. I am having the same connection problems with both SecurityAssisst and Datassist.
When I try to create the MySQL connection, I receive the following error:
MySQL error#: 1045
Access denied for user 'reflec3'@'localhost'(using password: YES)
Also, previous connections for another site that I have used with both SecurityAssist and Datassist successfully now show under the Dreamweaver tab as having no tables.
I have contacted my domain and attached a file that I copied from another site and changed the relevant info. such as login, etc. They report no errors with the file or problems reported with the database server.
Attached is the file that I submitted to the domain as an example.
How have you configured the Testing Server Tab of your Dreamweaver Site Definition?
if you have set the testing server tab to use a local folder, when you enter Localhost as the mySQL server it will try to connect to your local computers mySQL server.
To connect to the remote MySQL server, set the testing server tab to connect to your remote host via ftp. other wise, if you have a local server up and running, use that instead, it will increase the speed of the Data Base panels if it does not have to connect to the remote host.
martistott342331
testing server tab and connection problems
This post has been deleted.
martistott342331
remote server
It turns out that I did not use the correct server name (domain name) when setting up MySQL connection.
GerhardC
Ongoing Error#: 1045 issues
I'm a novice:
I lost my phpmyadmin access details, ... no solution I could find on the Internet worked.
Thus, I unistalled Xampp and installed a new version of it - not all could be uninstalled, but I managed to copy across a new version of what seemed to be the offending file being "config.inc.php"
Now I have access to phpmyadmin again via "root" as the username. I have changed the password to "1234" (for now").
I use Dreamweaver CS6 and have set-up my site as follows:
- Connect using: Local/Network
- Server Folder: C:\xampp\htdocs\websitefolder\
- Web URL: http://localhost/
- Server Model: PHP MySQL
Trying to install Security Pages and arranging Database Settings and Defining the same by selecting a database on the testing server is troublesome:
- New, MySQL Connection
- Connection Name: MyConnection
MySQL server: localhost
Username: root
Password: 1234
Select database: .... Error message: "The testing server for this site does not map to the http://localhost/_mmServerScript/MMHTTPDB.php URL. Verify that the URL Prefix maps to the root of the site."
I have no idea what that means - please help?
To note, I have refreshed the browser appropriately and reset Xampp appropriately. Thanks for your help.
Your testing server should be:
Web URL: http://localhost/websitefolder
to match the directory where you are saving the files
GerhardC
Xampp problems
Thanks very much. Now I have an error message that says Xampp does not see MySQL - please see the image attached.
That means you have to edit your php.ini file and enable the mysql module.
Find these lines in your php.ini file and make sure they don't have a semicolon in front of them:
extension=php_mysql.dll
extension=php_mysqli.dll
GerhardC
Xampp problems
Thank you Ray.
I could not find a file called "php.ini" on my computer. But I did find another with reference to the lines you have noted. However, I could only find extension=php_mysqli.dll and not extension=php_mysql.dll. It did not have a semi-colon in front of it. So, I needed to not change anything.
Please see attached. Thanks.
What version of php are you running? You will have to have a version less than v7 to work with mySQL and not mySQLi.
If you create a page with this code:
phpinfo();
It will tell you what version of php you are running.
