couple of 'issues' with a form
Thread begun 6/10/2013 6:57 am by Jamie | Last modified 6/18/2013 9:02 am by Jamie | 3986 views | 9 replies |
Jamie
Hey Jason
Have got a pretty lengthy form which is located here: http://www.cyoungopticians.co.uk/questionnaire.php?
Have 4 questions/issues I am facing:
1. there are 2 datepickers - one under Date of Birth and the other under date and time of assessment. For some reason, that I cant work out, the datepicker isnt showing when the field is clicked on.
2. The last field in the form (which is a yes/no radio) is required, but I seem to have lost the error text and focus?
3. in the sent email, is there any way to show the radio groups regardless of whether or not the user has inout a yes or no answer? or does it need to have an answer to achieve this?
4. is there a tutorial anywhere for retrospectively making a field required?
Have attached the file in case you needed it.
Many thanks
Jamie
1) there are a number of coding issues on this page that are causing the javascript to fail, for example:
<link rel="shortcut icon" href=favicon.ico" type="image/x-icon" />
should be:
<link rel="shortcut icon" href="favicon.ico" type="image/x-icon" />
<div class="fieldGrou;"> <span id="DOB_Spry"> <span>
should be:
<div class="fieldGroup"> <span id="DOB_Spry"> <span>
you have a number of elements that have commas in the name, this is not valid:
<input type="radio" name="Eyes_sting,_burn_or_sore_after_reading_for_a_while" id="Eyes_sting,_burn_or_sore_after_reading_for_a_while__1" value="Yes" class="formRadioField_Standard" tabindex="42">
form element names can contain only letters and numbers, those are jsut a few examples, i found that if i stipped all of the code from your page and had only the date picker elements in place, they started working, so there is a quite a bit of on this page that is badly formated and causing the problem.
2) Most likely a result of the coding issues from 1
3) It needs to have an answer to achieve this, the best bet is to add a Yes, No, NA option to each radio group and make NA selected by default.
4) Edit the server validation server behavior to add additional validations to the form.
Jamie
thanks Jason
Have spent ages troubleshooting this form and now have got the validations working and the datepicker but I havent got the success page sorted.
Basically the success content is held in the same page as the form itself and have put in
<?php if(isset($_SESSION["waue_VT_1_Status"]) && $_SESSION["waue_VT_1_Status"] == "Success") { ?>
//   Then the form goes here   //
<?php ?>
      <?php //var_dump($_SESSION); ?>
      <?php if(isset($_SESSION['waue_VT_1_Status'])) unset($_SESSION['waue_VT_1_Status']); ?>
I've obviously got a reference point wrong but not sure what I should be looking at....
Have attached the page file should you need it
Jamie
sorry Jason... forget the above as have managed to fix it and its working great.
Jamie
Jamie
On this same form, I have 2 datepickers. One is for current dates and one is for date of birth.
How would I go about changing the available years for the date of birth datepicker?
Cheers
Jamie
you would need to edit the date picker code, and add a yearRange argument:
the code for the DOB element is:
$(function(){
$('#DOB').datepicker({
changeMonth: true,
changeYear: true,
dateFormat: 'dd-mm-yy',
showAnim: 'show',
onClose: closeDatePicker_DOB
change that to:
$(function(){
changeMonth: true,
changeYear: true,
yearRange: '1950:2013',
showAnim: 'show',
Jamie
Jamie
Jamie
another quick Q Jason. How would I preselect a specific year for that datechecker?
add a default date:
defaultDate: '02/22/1989',
that will pre select February in the month list and 1989 in the year list
Jamie
thanks Jason
