Access secure pages after loggin
Thread begun 6/05/2013 6:57 am by Hitaroo | Last modified 6/05/2013 11:44 am by Jason Byrnes | 3945 views | 9 replies |
Hitaroo
Hi I have created a login page, with
e-mail
password
remember my details
auto log in
I have created a secure log in successful page using SecurityAssist, which works fine - it prevents the page being accessed directly. the user has to be logged in successful to the users table before access is granted, if access is denied (user is not logged in to the users table) it will take them to the log in page and they have log in to have access.
The problem I am facing is that even after the user has logged in with the correct e-mail and password access is denied to the log in page and the user is taken back to the log in page (index.php) with the following in the address bar:
http://www.hackneyhydroponics.co.uk/demo/index.php?accesscheck=%2Fdemo%2Flog-in-successful.php%3F
What am I missing? I have been through the post in the forum but can not find a solution.
After adding the secure page function using SecurityAssist the following code was added to the page:
<?php require_once( "../webassist/security_assist/helper_php.php" ); ?>
if (!WA_Auth_RulePasses("Logged in to users")){
WA_Auth_RestrictAccess("index.php");
I have also tried this using the Mange Site Access > Site Access Manager
most likely the server is not configured to sessions correctly.
use the attached session test file to ensure that the server can save sessions.
if the test fails, you will need to contact the host to have them fix the problem, it is probably the session.save_path setting in the php.ini file.
Hitaroo
Hi I have uploaded and tested the sessionTest.php file.
When I click the first link the URL changes to the following:
http://www.hackneyhydroponics.co.uk/demo/sessionTest.php?test=test
When I click the second link the URL reads:
I think the sessions are working as I have set a session on the log in page to capture the username from the DB after log in and display it on the log successful page, and that works fine.
Thanks for your help.
Hitaroo
Originally Said By: Hitaroo
Hitaroo
in the Logged into user rule, it was set to use the session:
SecurityAssist_userID
the login page was creating the session as:
SecurityAssist_UserID
(Upper case U).
I updated the rule to use the upper case U in the session name.
Hitaroo
(Upper case U).
i changed webassist/security_assist/helpergrouprules.php
use the security assist show region behavior to show a logged in message.
