Inline Editing not working CKEditor 4
Thread begun 6/04/2013 12:52 pm by CraigR | Last modified 6/05/2013 8:58 am by CraigR | 2326 views | 4 replies |
CraigRBeta Tester
I recently updated databridge and applied the patch for CKeditor, but I am finding the inline editing does not work, (it works fine when editing within admin)
Looking at other threads, I looked for /webassist/ckeditor in an absolute path, but I don;t have it anywhere - however looking at the page source, it looks as if it is there, which I am putting down to WA_CMS.php, especially this section...
$CMSMediaAdded = true;
echo('<script>var cms_root="' . rel2abs('../',dirname(__FILE__)) . '"; '."\n".'var pcms_toolbars = '.json_encode($toolbarsArray).'</script>
<script src="' . rel2abs('../webassist/ckeditor/ckeditor.js',dirname(__FILE__)) . '"></script>
<script src="' . rel2abs('WA_CMS.js',dirname(__FILE__)) . '"></script>
Is this the cause of my the problem ??
The live edit update is not intended for HTML Editor pages, it is intended for Power CMS Pages that use The Power CMS Builder from Design Extender.
Live editing is not supported on pages created using Data Bridge, it is not a feature that we have added, we will be adding it in the future.
It is only supported for pages that where created using Power CMS Builder in Design Extender.
CraigRBeta Tester
Ok, sorry, I sent midsleading information and am wondering what I have done to my Power CMS in that case
I will send you a PM link to my test site, hopefully you can see what I mean.
the firebug error console shows that the file:
/admin_cms/inline_edit.php
cannot be found
this is because you have installed to the admin older instead of admin_cms which is the standard location
the WA_CMS/WA_CMS.js file calls that file in the following line:
xmlHttp.open("POST", cms_root + "/admin_cms/inline_edit.php" ,true);
you will need to edit that to:
xmlHttp.open("POST", cms_root + "/admin/inline_edit.php" ,true);
so it is looking in the correct place.
CraigRBeta Tester
Thanks Jason.
I did look in firebug, but nothing appeared on errors or warnings, it is only now, when I clicked the 'all' button that the error appeared.
Thanks again for your detective skills
