Checkout Page Won't Display
Thread begun 6/04/2013 3:52 am by peterm.bruce341471 | Last modified 6/06/2013 9:57 am by Jason Byrnes | 4235 views | 9 replies |
peterm.bruce341471
Can you open a ticket as I don't want to display site details in the forum. The website I'm building with powerstore is working well but when you click the checkout button in the cart it re-directs to checkout.php but the page won't display, I get a server error yet I've checked and the file exists. I can't find the checkout button anywhere in the page files it seems hidden away.
Can you help, we really need to get the store launched!!
Thanks Jason,
Peter
peterm.bruce341471
I've attached as PM details requested.
Thanks Jason.
Originally Said By: peterm.bruce341471
Thanks Jason.
peterm.bruce341471
Jason, details attached.
The error occurs on trying to change from the http site to the secure https site.
some servers have a seperate upload folder for the http site versus the secured https site.
where you are using PayPal payments pro, it strongly recommended that you use the https address for the checkout, you will need to uplaod the power store files to the correct directory on the server for the https address, contact your host if you are unsure where that is.
for the time being, i have disabled the redirect to the https server by editing the webassist/plugins/checkout_form.php page and commenting the following code:
/*if ((empty($_SERVER['HTTPS']) || $_SERVER['HTTPS']=="off") && !isset($_POST["Checkout_x"]) && !isset($_POST["Checkout"]) && (time() - $_SESSION['WA_HTTPS_Redirect']) > 8) {
  if (!isset($_SERVER['REQUEST_URI'])) $_SERVER['REQUEST_URI'] = $_SERVER['PHP_SELF'];
  $testRedirect = "https://".$_SERVER['SERVER_NAME'].$_SERVER['REQUEST_URI'];
  $c = curl_init();
  curl_setopt($c, CURLOPT_URL, $testRedirect);
  curl_setopt($c, CURLOPT_TIMEOUT, 90);
  curl_setopt($c, CURLOPT_SSL_VERIFYPEER, 0);
  curl_setopt($c, CURLOPT_SSL_VERIFYHOST, 0);
  $result = curl_exec($c);
  if ($result)  {
      $_SESSION['WA_HTTPS_Redirect'] = time();
      header("location: ".$testRedirect);
      die();
once you have the files uploaded to the https location, you should uncomment that code.
peterm.bruce341471
Paypal Checkout Or Paypal Payments Pro Problem
  $c = curl_init();
  if ($result)  {
      die();
Jason,
I've installed an ssl certificate which is working fine but I'm now having problems processing transactions. I've re-instated the details you commented out and now the quick paypal checkout button does nothing when you click it and the direct payments pro method gives the error I've put in the PM section of this message.
Really struggling here, I'd be grateful for your assistance again.
Thanks,
Peter
the problem with the checkout form going to a failure was due to the way the shipping rule was configured, i updated the shipping rule to correct the problem.
i also updated the express checkout button to work, now the express checkout goes to checkout failure showing the following message from paypal:
Security errorSecurity header is not
this means the API credentials are being rejected, this can happen if the API Credentials are for a live account and you enable sandbox mode or vice versa, it can also happen if the you do not accept the billing agreement with paypal.
peterm.bruce341471
Solved
Jason,
Brilliant support as always - thank you so much. All the issues are dealt with, I really am very grateful.
Peter
you're welcome.
