Universal Email Page not loading
Thread begun 6/03/2013 7:28 am by msbannister373603 | Last modified 6/03/2013 2:32 pm by msbannister373603 | 2799 views | 12 replies |
msbannister373603
I've got a search and results page. I have universal email running on the results page so that I can email the results page. I've used this results page to email and it seems to work when not linked to a search page. Wierd!!!! For some reason when I use the search page to pass search criteria the results page will not load, when I have " any form post " selected in universal email wizard on the results page. Selecting 'any form post' is the only way that the email will be sent. If I choose a different trigger (other than any form post) the page will load but the email will not send. Any guess why the page will not load when I choose "any form post". I have the search wizard on the page first, then the universal email
msbannister373603
private
Originally Said By: msbannister373603
  private
msbannister373603
my bad
I'm not able to reproduce.
i login using the info you provided, go to the search page, perform a search, clicking the email button directs me back to the search page?
msbannister373603
That's because I have the trigger set to the submit Button. The page will submit fine but the email is not sent. If you change the trigger to any form post the email will send. The problem is that if you change the trigger to any form post the results page will not load . I changed it. so you will get the error now
So is the UE trigger set to re direct to the search page?
if so, leave the UE redirect blank so the results page will load
msbannister373603
the page loads but the email is not sending
