Pages produced by DataAssist wizard not working
Thread begun 6/03/2013 5:23 am by Roxana | Last modified 6/20/2013 4:47 pm by Roxana | 5735 views | 16 replies |
Roxana
I have successfully used the DataAssist wizard to create pages for updating my database before.
Now I wanted to create a few more pages, and it didn't work. This is what happened:
After the pages where generated, I wanted to try them out by typing this in the address bar: http://127.0.0.1/shop_multi-lingual/admin/tblversion_results.php
The page displayed without problem, but when I started a search, I just got an error message: Column 'language_id' in where clause is ambiguous
So I looked at the record set (there was one recordset). When I double clicked the recordset, the one recordset split into two without altering the page.
There is no WHERE clause in either of the recordsets, so I don't understand the error message.
When I now try to reload the initial page (without searching), I still get the same error message instead of the page I got when I first tried to access the page.
I tried the wizard again with another table, but still got the same results.
Could you please help me?
please send a copy of the pages so i can look at the code.
Roxana
Hi Jason,
I tried this with other tables, with the same results. Once I start a search, I get the "Column 'language_id' in where clause is ambiguous".
Also, I used the result page to delete one record (1 language), and it deleted the records with the same product id for all 7 languages.
This problem happens if you use the same column name in 2 tables.
I always recommend using unique column names in each table.
The naming convention i like to use for naming columns is to prefix the table name to the column name
where you are working with a version and language table, and example would be:
versions:
versionID - primary key
versionCompond
versionDescription
versionLanguageID - relates to languages.languageID
etc....
languages:
languageID - primary key
languageName
etc....
Using this naming convention prevents the ambiguous name error and prevents confusion since you can more readily identify the table a column name refers to by it's name.
to fix the probelm in your current pages, edit this code:
$WADbSearch1->addComparisonFromEdit("language_id","language_id","AND","=",1);
$WADbSearch1->addComparisonFromEdit("tbllanguage.language_id","language_id","AND","=",1);
the page you sent only deletes from the tblversion table, not the language table, i suspect the problem on your other page is related to the Key Column you selected.
Roxana
Thank you, Jason, that fixed this problem.
The other problem I mentioned occurred on the pages I generated for tblname2 (also a language relevant tbl). On those pages I selected a record in polish and deleted it (right on the result page), but it deleted not only the polish record, but the records with the same id for all other languages. I did not mean it deleted records in other tables.
I think this will happen again, also with tblversion, because when I click on the version id to open the detail page, it will open the german record, not the language that was displayed when I clicked on the version id.
What baffles me is, that I used the same wizard to generate pages for another, also language relevant table. And with those pages I have no problems. It opens the detail page in the chosen language and only updates that language.
Roxana
Hi Jason,
I did not put the pages online. I do all data entry on my local server and then upload the sql file to the external server.
Originally Said By: Roxana
  Hi Jason,
Roxana
Thanks, Jason
  Thanks, Jason
