Double opt registration I'm missing missing "Insert Record (users)" in server behavior.
Thread begun 6/02/2013 11:46 pm by aaarman | Last modified 6/24/2013 9:23 am by Jason Byrnes | 4347 views | 9 replies |
aaarman
I have deleted all the files and restarted the process from the beginning again but can't find "Insert Record (users)". Is there a way for me to manually create that behavior?
Alexander
send a copy of your page please.
aaarman
A copy of the page
Hello Jason,
I hope I understood you right. This is the page I was at working through the tutorial. Got stuck right at 9 minutes and 19 seconds of the tutorial.
there is no insert record behavior on this page. It should have been added when you ran the Security Assist wizard to create the security assist pages at the start of the tutorial.
It can be added manually by going to the Server behaviors panel, clicking the plus button and selecting WebAssist -> Data Assist Insert Record -> Single record Insert, though it is best to have this added by the Security Assist Wizard
aaarman
How do I finish it?
I started one more time from the beginning and did everything step by step still no InsertRecord. I followed your instruction but I don't know what to choose on the menu that comes after.
When you run the security assist wizard in the first step, what are the settings you are using? the security assist wizard should add the insert behavior to the registration page.
You need to enter a name for the ID Session variable in the session section, then on the bindings panel, bind the columns of the users table to the form elements in the registration page.
aaarman
Can this message be the problem
Hello Jason,
I start the process with a simple page saves as index.php and follow the instruction of the lady on youtube tutorial for almost 10 minutes. There is no setting involved in her instructions. The message in the picture comes up when I start my Dreamweaver. Do you think that has something to do with it? Can you give me instruction on how to remove my webassist wizard and re-install it if that helps? I have attached a list of all my files and folders that get created by the wizard.
What extensions including the version numbers are installed?
The only extensions that we offer that are compatible with DW CS 6 are:
eCart
Free Tools
Design Extender
Data Bridge.
if you have any other webassist extensions that should be uninstalled.
The very first step of the Double Opt In tutorial is to run the Security assist wizard to create the Registration and log in pages.
aaarman
Insert Record (users) is missing from Server Behavior
Hello Jason,
I had to give up on this subject last time. I'm trying it again on a new site. I have the same problem. I start running the wizard by going to Webassist > Security Assist > Create Security Pages. The wizard does not complete the process. It gave me the message attached.
I have carefully looked and there are no other extensions than Free Tools, Data Bridge and Design Extender.
Alexander
Originally Said By: aaarman
  Hello Jason,
Alexander
