JS error while executing timer
Thread began 5/29/2013 9:32 pm by Brendan | Last modified 5/30/2013 8:46 am by Brendan | 716 views | 2 replies |
Brendan
I am running DWCS6, and the latest version of Data Bridge. I was trying to build a product catalog with the wizard, and when the WA Site Tools starts to run I get this error message "While executing time in WA_SiteTools_ProgressV2.htm, the following JS error occured:
At line 125
C:\Users\Name\AppData......\en_US\Configuration\Floaters\WA_SiteTools_ProgressV2.js": col has no properties.
So I followed the advice in an older post, removed ALL of my extensions, deleted the config folder, and reinstalled my WA extensions (eCart, then Design Extender, then Data Bridge).
Reran the wizard, all worked fine...except, I didn't notice that the wizard did not recognize that I was using my own table, so it created all of the pages assuming a connection to db/products, and with the generic fields.
So I deleted the pages that were created, and reran the wizard again. This time making sure to uncheck "create a database table for me". I had to select a different page type, and reselect product catalog for it to recognize my DB table and fields. Finished the wizard, and the same timer js error is occurring again.
This is probably a perfect storm of me rushing through the wizard, but i'm hoping there is a way to fix this other than deleting the config folder again....
Please help,
Thank you!
The application presets are intended to be used with the table they where designed for, either by having the wizard create the table for you, ort by having a table with the same structure already created.
when using your own table that does not match the structure of the application preset, it is best to use the New From Blank preset to create the pages. After setting up the pages, you can them save a preset for that that table to be used in the future.
Brendan
Thanks Jason,
I figured I was doing something wrong.
