Warning: Missing argument 7 for eCart1_ItemDefinition
Thread begun 5/29/2013 9:53 am by Informa | Last modified 8/01/2013 1:03 am by Informa | 4952 views | 10 replies |
Informa
Warning: Missing argument 7 for eCart1_ItemDefinition::eCart1_ItemDefinition(), called in WA_eCart_Definition_PHP.php(477) : eval()'d code on line 1 and defined in eCart1_PHP.php on line 257
Hi, my name is Mario,
This error happens when I view the cart after adding more than one product in the cart.
http://www.cativegrama.com/html/produtosResultPesq.php?pesquisa=espanador&button=OK
Someone can help me on this problem?
send a copy of the eCart1_PHP.php page
Informa
eCart1_PHP.php
i am not able to reproduce the problem on that page.
I have added about 10 items to the cart without reproducing the error.
Informa
the problem is random
Jason, the problem does not always appear. I've been testing and it happened after 4 products added, the problem is random. You can test as many times as you need to. No problem
Sorry if my English is not correct, I am Portuguese.
I am very grateful if you solve this problem
I have now added 15 items to the cart with out reproducing the problem.
does it happen with a specific product?
Informa
Hi Jason,
Yes, this problem happen with some product, but I have analyzed the products causing the problem and can not identify the problem in the database.
Here has a product that causes the problem, "order" and then "view cart"
http://www.cativegrama.com/html/produtosIDFamSubFam.php?selectFamilia=20&selectSubFamilia=80&button2=OK
Informa
I think these are the elements that you want, see the private message section
in the add to art code, i change:
$ATC_itemName = "".$row_rcsProdutos['nomPrd'] ."";// column binding
to use htmlentites:
$ATC_itemName = "".htmlentities($row_rcsProdutos['nomPrd']) ."";// column binding
which corrected the error.
