Pass record ID without using URL
Thread begun 5/28/2013 8:27 am by mrs | Last modified 5/28/2013 11:17 am by mrs | 1212 views | 2 replies |
mrs
I've asked this question on Adobe's forum, but surprisingly, I've not had any response... but plenty of views, so I thought I'd see if the old faithful community comes up trumps! I just need some idea on how to approach the following.
I need to pass a record ID when a user clicks a link, but I don't want to pass it via the URL. I can't figure out how to do so.
I have built a forum, and the forum users want to be able to quote a post and the respective replies. So, just like this forum, you have an original post, and then you have a repeating region of numerous replies below. So, what I need to do is enable the page to identify the unipue ID of the clicked record to quote from others that might also be available on the page, but without passing a URL variable, I can't figure out how to do it.
I would like to be able to set a session variable, but I don't know how to acheive this via a link so that I am passing the correct record ID.
Does naybody know how I can do it?
If possible, I don't want to use a URL variable for security reasons.
Thanks.
The only thing i can think of would be to use a form post instead of a link
add a form with a hidden element. set the value of the hidden element to the ID that you want to pass.
Use a submit button and set the value to your link text. when the form is submitted the hidden element will pass the ID through the POST.
mrs
Excellent! I knew I get some sense from here.
Thank you Jason.
