HTML Editor 2, image upload and other problems
Thread begun 5/27/2013 3:46 pm by Lon Winters | Last modified 9/03/2013 7:26 am by Jason Byrnes | 2515 views | 3 replies |
Lon WintersBeta Tester
Inserted, configured and tested. No problems with entering and displaying text content. Moved on to images. The tab for upload images, stated it wasn't available or not enabled, or whatever the message is.
Went back in a configured the upload folder, set write permissions. Added a SA rule which I also use for the general login page and it works. Selected that rule in the HTML Editor dialog. That box shows 'Everyone' along with the rule I created. I just select my rule, which I assume is all it takes to make the selection, since there is no other button to confirm the selection. Is that correct?
Changed the preset to Advanced Managment, and tested. Now, when I click on the image button in the edit, I don't get the tab set, just text and it's completely non functional. So apparently I messed up the style settings somewhere. I did not use any custom styling, just the default skin.
Deleted everything to start over. Just using the Default Manager preset. I wanted to also delete all the database tables and start from scratch there, but in phpMyAdmin, there is no option to drop these tables. How can I do that?
So, I'm uploading all the files now, just thought I'd post these questions while waiting.
Also, what is the different between the Default and Advanced preset?
Edited: Image upload is working and allows me to do what I need, basically just resize the image. Now I guess my one question remains, what is the different between the Default and Advanced editor presets - if I change it to Advanced, what additional features will I get? Thanks.
The Advanced Image Editing Preset enables options in the file manager for Cropping or Rotating the images.
With the advanced preset, in the upper right hand corner of the file manager screen, there will be icons for the advanced options. Or you can right click the image in the file manager to access the advanced editing options.
I was just going through my posts and saw that I never provided a followup to this question I asked.
I realized that for whatever reason, the Editor, or at least the version I'm using doesn't play well with Windows Safari. Went over to Chrome and all worked great! haven't tired IE or FIrefox yet, but it's not a big deal. I'm probably in a small minority who uses Safari on Windows as their default browser. And I doubt that anyone over at Apple loses any sleep over making sure the Windows version is all buttoned up.
Ok, glad to hear you have it working in Fire Fox.
