DataAssist Wizard showing incorrect fields
Thread begun 5/23/2013 10:45 am by Paul | Last modified 5/24/2013 8:24 am by Jason Byrnes | 2135 views | 3 replies |
Paul
I have Design Extender installed with CS6 on Windows 8 Pro.
I am using the DataAssist Create Pages Wizard to make a Product Catalog. There is also a PowerCMS database on the server in MYSQL.
The correct connection is selected, with the correct table selected first. I am using the Basic design and Product Catalog is the Application Type.
When I go into the Managed Pages Tab, it shows the Search, Results and Details page. But when I go into the Configure Field Settings, the incorrect Database Fields are showing. They are not showing the fields that I set up in MYSQL, although the correct Database Connection and Table are selected in the prior Tab.
Any idea why it is picking up the wrong fields?
Do you have the option to create the table selected? When using predefined preset, it will be based on the a predefined table, the default option will be have the wizard create that table. If you are using your own table, it is best not to use one of the Application presets, it is best to use the New From Blank option, and create your own preset for that table.
Paul
I see what you are saying. All I am trying to do is create the search, results and details pages, but DW6 crashes every time I run the wizard.
What other extensions do you have installed, including the version numbers?
Was Data Bridge Extension to be installed?
Make sure you have the most recent version installed 1.1.2
Try uninstalling Data Bridge, then installing it again.
