My Security Assist Wizard page display shows ]]> little window should , acutual page DW shows much coding than should been learning double opt registration system deleated my pages
Thread begun 5/22/2013 3:15 pm by dee | Last modified 5/28/2013 1:16 pm by dee | 2271 views | 6 replies |
dee
My Security Assist Wizard page display shows ]]> in the little Wizard window and the actual DW page shows too much coding. I have been learning the double opt registration system and have deleted my pages to try the system again, but now I have the ]]> i
Hi Jason,
I'm wanting to rebuild from scratch my Double Opt in Registration System. but I'm worried I may have to reload the Data Bridge because of the Validation problem of ']]>'. I get this in the Wizard Window when I reuse a saved precept. OR when I tried to remake and save a new precept or use the standard precept option from the Wizard.
Please help
THank you (It appears my hole is getting deeper the more I try to assist myself, I may even see China!!)
Deeanna
make sure you have the most recent version of Data Bridge installed:
version 1.1.3 if you have a previous version, please uninstall it before installing the newer one.
dee
Data Bridge version.
I am up-to-date with the Data Bridge version.
Try uninstalling it and re installing.
dee
Thank you
Jason,
THank you reinstalling solved that problem of ]]>.
Dee
No this is not an issue.
Both eCart and Cookies Toolkit include the set session value behavior, they work exactly the same though. No difference if it is labeled an eCart behavior over a Cookies toolkit behavior.
dee
THank you Jason for that clarification
Thank you Jason, you are terrific with your understanding and instructions.
Deeanna
