CSS Menu Link Box not working
Thread begun 5/22/2013 1:53 pm by john70964 | Last modified 5/29/2013 12:12 pm by Jason Byrnes | 4331 views | 11 replies |
john70964
When I type in the Edit Menu Content I am getting / instead of the letter.
Please see images attached
Thank you.
make sure you have the latest version of Design Extender (1.1.2) installed.
if you have a previous version installed, make sure to uninstall it before installing the newer version.
john70964
Thanks Jason
I have installed 1.1.2 with no hitches
I created a menu within a DWT but when I run the menu the url is http://localhost/productlist.php and not http://localhost/mydomain/productlist.php
If I open and run menu.php the links go to the correct page.
send a copy of you p[age please and the menu.php file
john70964
Thanks Jason
Here are the zips attached
john70964
By the way
You will notice on the attempt attached I did not place the menu writer on the template although I had previously. I tried placing them straight onto the page.
I did place a couple of text links on the DWT and they work OK so I may use that
Originally Said By: john70964
  Thanks Jason
john70964
Thanks Jason
I will skype you later, user name is johnhardy2006
john70964
Thank you Jason
Sorry to have missed you, I did try on Friday but Skype reported you away.
I expect the problem with the menu may be that I am trying to use it with a Cart Weaver page.
I am having problems with skype at the so will contact you later.
Regards
John
Ok, I will be ready when you contact me.
