UPS charges in cart summary
Thread begun 5/21/2013 2:20 pm by info374483 | Last modified 6/19/2013 1:10 pm by Jason Byrnes | 7550 views | 34 replies |
info374483
I have added UPS real time in the Checkout Wizard. I am not seeing the shipping charge or the tax in the carts order summary before going to checkout. How can I get the shipping charge and tax to show before going to checkout?
Also if I did not want to include the checkout form on my site but go straight to Paypal to check out how would you link to that?
Tax are shipping are calculated based on the Shipping information that is entered in the checkout form.
it is not possible to calculate the tax or shipping before the checkout form is completed.
Once you fill in the checkout form, the confirm page will show the shipping and tax in the cart summary.
delete the checkout form from the checkout page.
on the cart page, set the checkout server behavior to pass a URL Variable to the checkout page:
checkout.php?Express=true
on the bindings panel, click the plus button and select URL variable, name it "express"
on the checkout page, double click the Authenticate transaction with paypal express. for the trigger, click the lightning bolt icon and select the express URL variable.
info374483
OK I think I will go ahead and keep it like it is using the checkout form on my site. If I was to delete the checkout form, does the realtime UPS shipping and tax get included on paypal checkout form?
If not deleting the checkout form I have another problem...when you enter an order and fill the checkout form but dont submit the order and you go back the shipping and tax are showing in the cart, so when you add another couple of items to the cart, the shipping stays the same. Why would the shipping be shown in the cart when going back to the cart if it did not show in the cart from the beginning.
Also the UPS charges are way to much. Im using Ground for 3 lbs. it charges 37.00 for shipping. When I do a quote at UPS it is only 9.00. In the ecart object I set the weight to oz, and UPS uses LBS.
With express checkout, the user goes to the paypal site to enter the billing and shipping info, they are then returned to your site and the shipping and tax are calculated. they have the option to confirm the transaction or not at that point.
once the tax and shipping are calculated, they are stored in a session. you can add a clear session value server behavior to the cart display page to clear the tax and shipping sessions so they are not shown.
have you run the checkout wizard multiple times?
If you run the checkout wizard multiple times, it will add multiple behaviors for looking up the shipping, this will cause the shipping rate to increase.
if you need to re run the checkout wizard, make sure you delete the existing checkout pages first.
info374483
Yes I have ran the checkout wizard more than once. But I always delete all the pages that it creates from my side and the server before running it again. Here is the code that I am using. What is the shipper number? Also I have set ecart object to OZ but confirm page is set to LBS for UPS.
$Shipping_Parameters["CarrierCode"] = "03";
$Shipping_Parameters["PickupType"] = "01";
$Shipping_Parameters["CustomerClass"] = "none";
$Shipping_Parameters["ShipperNumber"] = "";
$Shipping_Parameters["ShipperCity"] = "Houston";
$Shipping_Parameters["ShipperState"] = "TX";
$Shipping_Parameters["ShipperZip"] = "77024";
$Shipping_Parameters["ShipperCountry"] = "US";
$Shipping_Parameters["ShiptoCity"] = "".((isset($_POST["shipping_city"]))?$_POST["shipping_city"]:"") ."";
$Shipping_Parameters["ShiptoState"] = "".((isset($_POST["shipping_state_province"]))?$_POST["shipping_state_province"]:"") ."";
$Shipping_Parameters["ShiptoZip"] = "".((isset($_POST["shipping_postcode"]))?$_POST["shipping_postcode"]:"") ."";
$Shipping_Parameters["ShiptoCountry"] = "".((isset($_POST["shipping_country"]))?$_POST["shipping_country"]:"") ."";
while (($Shipping_Packaging == 1 && !$eCart1->EOF()) || ($Shipping_Packaging == 0 && $Shipping_Counter == 0)) {
if (WA_eCart_UPS_IsTrueValue("true")) {
$Shipping_PackageArray[] = array();
$Shipping_PackageIndex = sizeof($Shipping_PackageArray)-1;
$Shipping_PackageArray[$Shipping_PackageIndex]["eCart_Quantity"] = (($Shipping_Packaging == 1)?$eCart1->DisplayInfo("Quantity"):1);
$Shipping_PackageArray[$Shipping_PackageIndex]["IsPackage"] = "true";
$Shipping_PackageArray[$Shipping_PackageIndex]["Quantity"] = "".WA_eCart_FormatNumber($eCart1->DisplayInfo('Quantity'), true, 1) ."";
$Shipping_PackageArray[$Shipping_PackageIndex]["WeightUnits"] = "LBS";
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageWeight"] = "".WA_eCart_FormatNumber($eCart1->TotalColumn('TotalWeight'), true, 1) ."";
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageType"] = "02";
$Shipping_PackageArray[$Shipping_PackageIndex]["SizeUnits"] = "IN";
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageLength"] = "10";
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageWidth"] = "10";
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageHeight"] = "5";
The shipper number is a part of your UPS account, UPS Should have given you that number.
in the server behavior, you will need to change the weight units to match the cart object.
info374483
OK I will call UPS and get the shipper number. I thought that all you needed was the account number, password and security key.
Anyway...new problem....I added a select field to the checkout.php page for UPS Ground, 2nd Day Air, etc...and I went to set a session value for the UPS_Service session form field. I am getting the same UPS rate as Ground and 2nd Day Air. Am I missing something here to bind something else to the select field? Sorry but getting frustrated.
YOU SAID in the server behavior, you will need to change the weight units to match the cart object.
If I change the server behavior to OZ I get an error from UPS. I guess they dont accept OZ only LBS.
see message 2 in this post for details on adding fields to the checkout form:
http://www.webassist.com/forums/showthread.php?t=22392
info374483
Yes I did both of those steps except this one.
in the store order summary behavior, you will need to bind the new database columns to the corresponding form element
Would I enter this field in the orders table or the detail table? Also would I name the field UPS_Service?
the new fiield would be added to the orders table. you could use UPS_Service service for the name.
also, make sure you edit the UPS Shipping rate server behavior and bind the service to the session that is set.
