DW 6 Crashes When Adding "Results" Feature to Page
Thread begun 5/20/2013 10:31 pm by Eric | Last modified 5/30/2013 9:21 pm by Eric | 1951 views | 4 replies |
Eric
Whenever I add the "results" feature to the Manage Pages module of DataAssist, Dreamweaver immediately crashes. The only information I can pull from the computer relating to this error is "An unhandled win32 exception occurred in Dreamweaver.exe [10152]."
To my knowledge, I am running the latest version of Dreamweaver CS6, and the DataAssist extensions. I am running these on Windows 8 64 bit. Any help would be greatly appreciated.
Are you using one of the Application presets? Or using the New From Blank option?
Are you using your own table? Or having the wizard create the table for you?
If you are using your own table, please send an SQL dump of the structure so i can try to reproduce the problem. It may be a column name using a Reserved word. or it may be a specific data type.
Eric
Thanks for the quick reply Jason. I am using the blank form option, with my own table. I've attached an SQL dump of the tables used in this application, the table I am specifically having trouble with is the users table.
most of the columns in your users table use the text data type. It is a better practice to use the varchar datatype and specify a length, for example limit the username to 50 characters
the text data type allows for a large amount of data, using it for all your columns is a bad practice. it should only be used for columns where you want to allow more than 255 characters which is the limit to the varchar column type.
Eric
Gotcha. Makes sense. Got it working after changing the table structure. Thanks!
