Moving hosting server ip with godaddy caused the CMS system to completely fail.
Thread begun 5/20/2013 9:40 am by aaronjkizer366105 | Last modified 5/20/2013 10:13 am by Jason Byrnes | 2634 views | 5 replies |
aaronjkizer366105
Warning: include(/home/content/j/s/f/jsfender/html/veritycms/WA_CMS/addtosite.php) [function.include]: failed to open stream: No such file or directory in /home/content/98/4522298/html/index.php on line 77
I have not moved the mysql server. All of it's information is the same. This has also affected my security assist pages.
Warning: session_start() [function.session-start]: open(/var/chroot/home/content/98/4522298/tmp/sess_tt91niiakbv6ffcp2s0rnenth7, O_RDWR) failed: No such file or directory (2) in /home/content/98/4522298/html/WA_SecurityAssist/Helper_PHP.php on line 5
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/content/98/4522298/html/WA_SecurityAssist/Helper_PHP.php:5) in /home/content/98/4522298/html/WA_SecurityAssist/Helper_PHP.php on line 5
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/content/98/4522298/html/WA_SecurityAssist/Helper_PHP.php:5) in /home/content/98/4522298/html/WA_SecurityAssist/Helper_PHP.php on line 5
Warning: Cannot modify header information - headers already sent by (output started at /home/content/98/4522298/html/WA_SecurityAssist/Helper_PHP.php:5) in /home/content/98/4522298/html/WA_SecurityAssist/Helper_PHP.php on line 67
Warning: Unknown: open(/var/chroot/home/content/98/4522298/tmp/sess_tt91niiakbv6ffcp2s0rnenth7, O_RDWR) failed: No such file or directory (2) in Unknown on line 0
Warning: Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct () in Unknown on line 0
Thank you for any assistance you can provide.
The first issue with The CMS pages:
your CMS PAges will contain a require once line to link the WA_CMS/addtosite.php page which uses a server specific path
include('/home/content/j/s/f/jsfender/html/veritycms/WA_CMS/addtosite.php');
open the CMS Admin panel and select a CMS Content area.
in the main screen click the Developer Notes link. this wil show the code for adding that content area to your page and should contain the correct path for the include line.
copy the include line, and edit your pages to use the new path.
For the Security Assist error:
This is a probelm with the session.save_path setting in the php.ini
you will need to contact godaddy support for assistance in correcting this issue.
aaronjkizer366105
Thank you for the reply. Unfortunately I cannot even log into my CMS system.
That's the session management issue.
since the session.save_path in the php.ini does not exist, sessions cannot be saved.
you wil need to work with go daddy support to correct that issue, once that is corrected, the CMS login should work, so you can correct the other issue.
aaronjkizer366105
Thank you very much Jason. I will work with them to fix it. My assumption is that some other issues will also clear up with that, like my data assist.
if you need further assistance, please let us know.
